Installing pyclearpass
Package Installation
Follow a method within this section of the guide to help you install the pyclearpass package.
Python Requirements
Ensure Python v3.9 or greater is installed on your operating system
Method 1 - Installing Package from PyPi
Run the following in a command line terminal to install the pip package directly from Pypi- pip3 install pyclearpass
or pip install pyclearpass
. This may vary between operating systems. The PyPi repository is located here for reference.
Method 2 - Installing Package from Github (not using Git executable)
- Click into the HPE Aruba Networking Github Repository where the latest version of pyclearpass is located
- Click Code (in green) and Download to Zip
- Extract the zip file into a directory
- Go into a command line terminal and change directory (cd) into the folder where you extracted the zipped file and then down one child folder. The folder contents should pyclearpass (FOLDER), LICENSE, pyproject.toml and README.md
- In your command line terminal type
python3 -m build
orpython -m build
. This will create a folder called dist with a file containing a .gz extension. - Run the following in a command line terminal to install the pip package -
pip3 install pathtozip.gz
orpip install pathtozip.gz
. This may vary between Operating Systems.
Method 3 - Installing Package from Github (using Git executable)
- Install Git for your Operating System from https://git-scm.com/download
pip3 install git+https://github.com/aruba/pyclearpass
orpip install git+https://github.com/aruba/pyclearpass
Updated 4 months ago
Whatβs Next
