Ansible Examples
Example for connecting to Orchestrator API
Your use of this Software is pursuant to the Silver Peak Disclaimer - see the README file for this repository
Basic LOGIN function without multi-factor authentication, requires Orchestrator URL, User, Password
Throughout example LOGIN response is stored and used in variable {{ orch }}
NOTE: orch_ip can be IP address or URL, if the orch_user is using RBAC, they must have R/O or R/W access
- name: Orchestrator Login
 uri:
 validate_certs: # (yes/no)
 url: "https://{{ orch_ip }}/gms/rest/authentication/login"
 body: {"user": "{{ orch_user }}", "password": "{{ orch_password }}"}
 body_format: json
 return_content: yes
 method: POST
 headers:
 Content-Type: "application/json"
 register: orch
LOGOUT function, requires Orchestrator URL, and {{ orch }}
- name: Orchestrator Logout
 uri:
 url: "https://{{ orchip }}/gms/rest/authentication/logout"
 body_format: json
 return_content: yes
 method: GET
 headers:
 Cookie: "{{ orch.set_cookie }}"
 X-XSRF-TOKEN: "{{ orch.cookies.orchCsrfToken }}"
Sample GET function, requires Orchestrator URL, GET URL (shown as variable), and {{ orch }}
GET response stored in variable {{ getReturn }}
- name: Get Sample
 uri:
 url: "https://{{ orchip }}/gms/rest/{{ get_url }}"
 body_format: json
 return_content: yes
 method: GET
 headers:
 register: getReturn
Sample POST function, requires Orchestrator URL, POST URL (shown as variable), and {{ orch }}
NOTE: for error handling, POST STATUS may be returned as 200 or 204, either hardcode or leverage variable accordingly
- name: Post Sample
 uri:
 url: "https://{{ orchip }}/gms/rest/{{ post_url }}"
 body: "{{ contents }}"
 body_format: json
 return_content: yes
 status_code: "{{ post_status }}"
 method: POST
 headers:
Sample PUT function, requires Orchestrator URL, PUT URL (shown as variable), and {{ orch }}
NOTE: for error handling, 204 status code may be returned on successful PUT and should be set accordingly as necessary
- name: Put Sample
 uri:
 url: "https://{{ orchip }}/gms/rest/{{ put_url }}"
 body_format: json
 return_content: yes
 status_code: 204
 method: PUT
 headers:
Updated over 1 year ago
