Orchestrator Alarm Catagories & Index Values
GMS ALARM ID BASE
Integer ORCH_ALARM_ID_BASE = 100;
//Integer ORCH_SP_ALARM_ID_BASE = 200;
* GMS ALARM CATEGORIES
Integer GMS_ALARM_CATEGORY_BASE = 0;
Integer GMS_ALARM_CATEGORY_TUNNEL = 1;
//Integer CALARM_CATEGORY_TRAFFIC_CLASS = 2; // Used by appliance only
Integer GMS_ALARM_CATEGORY_EQUIPMENT = 3;
Integer GMS_ALARM_CATEGORY_SOFTWARE = 4;
//Integer CALARM_THRESHOLD = 5; // Used by appliance only
* GMS ALARM INDEX
//GMS ALARM TUNNEL CATEGORY
Integer INTERFACES_WITH_DUPLICATE_IP_EXIST = 0;
Integer INTERFACES_WITH_NO_PUBLIC_IP_EXIST = 1;
Integer FAILED_TO_APPLY_OVERLAY_CONF = 2;
Integer ACL_NOT_DEFINED = 3;
Integer INTERFACES_WITH_DUPLICATE_LABEL = 4;
Integer INTERFACES_WITH_DUPLICATE_PUBLIC_IP_EXIST = 5;
Integer FAILED_TO_TUNNEL_GROUP = 6;
Integer BAD_WAN_IP = 7;
Integer MISSING_WAN_LABEL_FOR_OVERLAY = 8;
Integer MISSING_LAN_LABEL_FOR_OVERLAY = 9;
Integer TUNNEL_ENDPOINT_IP_VERSION_MISMATCH = 10;
Integer FAILED_TO_APPLY_LABELS = 11;
Integer FAILED_TO_APPLY_INTERNAL_SUBNETS = 12;
Integer FAILED_TO_APPLY_APPLICATION_CLASSIFICATION = 13;
Integer APPLIANCE_IPSEC_UDP_PORT_CONFLICTS_WITH_HA_PEER = 14;
Integer OVERLAY_AND_TUNNEL_GROUP_ARE_BOTH_ON = 15;
Integer OVERLAY_HAS_NO_HUBS = 16;
Integer OVERLAY_HAS_NOT_INTERFACES_DEFINED = 17;
Integer TUNNEL_GROUP_HAS_NO_HUBS = 18;
Integer TUNNEL_GROUP_HAS_NOT_INTERFACES_DEFINED = 19;
Integer FAILED_TO_APPLY_TEMPLATES = 20;
Integer FAILED_TO_APPLY_PORT_FORWARDING_RULES = 21;
Integer OVERLAY_HAS_LOCAL_BREAKOUT_WITHOUT_INTERFACES = 22;
Integer MAXIMUM_TUNNELS_EXCEEDED = 23;
Integer OVERLAY_REGION_MISSING = 24;
Integer DUPLICATE_HOSTNAME = 25;
Integer ORCHESTRATOR_POSSIBLY_UNDER_RESOURCED = 26;
Integer MESH_OVERLAY_HAS_NO_HUBS = 27;
Integer MESH_TUNNEL_GROUP_HAS_NO_HUBS = 28;
Integer MISSING_PUBLIC_IP_FOR_WAN_LABEL = 29;
Integer ORCHESTRATION_FAILED = 30;
Integer HUB_NOT_USED_IN_ANY_OVERLAY = 31;
Integer DUPLICATE_APPLIANCE_IPSEC_UDP_PORT_AT_SAME_SITE = 32;
Integer INTER_REGION_ROUTING_OFF = 33;
Integer ONLY_INLINE_ROUTER_SUPPORT = 34;
Integer APPLIANCE_NOT_IN_REGION = 35;
Integer CHECK_POINT_SITE_PARAMS_WRONG = 36;
Integer FAILED_TO_APPLY_TRAFFIC_BEHAVIOR = 37;
Integer MISSING_GEO_LOCATION = 38;
Integer UNSUPPORTED_TUNNEL_MODE_FOR_EDGE_HA = 39;
Integer INTERFACE_BANDWIDTH_CHECK = 40;
Integer TUNNELS_WITH_SAME_SOURCE_PORT_EXISTS = 41;
Integer APPLIANCE_IPSEC_UDP_PORT_CONFIGURATION_SET_TO_MANUAL = 42;
//GMS ALARM EQUIPMENT CATEGORY
Integer DISK_USE_WARN = 0;
Integer DISK_USE_MAJOR = 1;
//GMS ALARM SOFTWARE CATEGORY
Integer APPLIANCE_CLONE_DISCOVERED = 0;
Integer APPLIANCE_BACKUP_FAILED = 1;
Integer APPLIANCE_DUPLICATE_SERIAL_NUM = 2;
Integer APPLIANCE_TIME_OFF = 3;
Integer UNREACHABLE_APPLIANCE = 4;
Integer APPLIANCE_NOT_SUPPORTED = 5;
Integer APPLIANCE_REBOOT_NEEDED = 6;
Integer APPLIANCE_SAVE_NEEDED = 7;
Integer APPLIANCE_DOES_NOT_SUPPORT_IPSEC_UDP = 8;
Integer LOGIN_FAILED = 9;
Integer INVALID_GMS_LICENSE = 10;
Integer GMS_LICENSE_EXPIRES_45D = 11;
Integer GMS_LICENSE_EXPIRES_15D = 12;
Integer GMS_LICENSE_EXPIRED = 13;
Integer PORTAL_CONNECTIVITY = 14;
Integer PORTAL_CONNECTIVITY_WARNING = 15;
Integer PORTAL_BAD_REG_CREDENTIALS = 16;
Integer ALARM_EMAIL_NOT_SET = 17;
Integer SMTP_DEFAULT_NOT_CHANGED = 18;
Integer CPX_LICENSE_EXPIRES_45D = 19;
Integer CPX_LICENSE_EXPIRES_30D = 20;
Integer CPX_LICENSE_EXPIRES_15D = 21;
Integer CPX_LICENSE_EXPIRED = 22;
Integer EC_LICENSE_EXPIRES_45D = 23;
Integer EC_LICENSE_EXPIRES_30D = 24;
Integer EC_LICENSE_EXPIRES_15D = 25;
Integer EC_LICENSE_EXPIRED = 26;
Integer SAAS_LICENSE_EXPIRES_45D = 27;
Integer SAAS_LICENSE_EXPIRES_30D = 28;
Integer SAAS_LICENSE_EXPIRES_15D = 29;
Integer SAAS_LICENSE_EXPIRED = 30;
Integer BACKUP_CONFIGURATION_NOT_SET = 31;
Integer SMTP_SETTINGS_BLANK = 32;
Integer EMAIL_DELIVERY_FAILED = 33;
Integer GMS_APPLIANCE_CLONE_DISCOVERED = 34;
Integer GMS_BACKUP_FAIL = 35;
Integer FAILED_TO_UPDATE_APPLICATION_CLASSIFICATION = 36;
Integer FAILED_TO_UPDATE_TRAFFIC_BEHAVIOR = 38;
Integer EXCEEDED_CLOUD_DEPLOYMENT_SIZE = 39;
Integer REMOTE_ACCESS_ENABLED = 40;
Integer APPLIANCE_EXCLUDED_FROM_ORCHESTRATION = 41;
Integer OVERLAY_WORK_PAUSED = 42;
Integer FAILED_TO_APPLY_APPLIANCE_PRECONFIGURATION = 43;
Integer AUTO_SAVE_OFF = 44;
Integer TEMPLATE_APPLY_PAUSED = 45;
Integer GMS_NOT_REGISTERED = 46;
Integer FAILED_TO_CONNECT_TO_ZSCALER = 47;
Integer CLOUD_ORCHESTRATOR_EXPIRES_15D = 48;
Integer EC_BOOST_LICENSE_EXPIRES_45D = 49;
Integer EC_BOOST_LICENSE_EXPIRES_30D = 50;
Integer EC_BOOST_LICENSE_EXPIRES_15D = 51;
Integer EC_BOOST_LICENSE_EXPIRED = 52;
Integer INTERNAL_DROPS = 53;
Integer PAUSE_STATS_COLLECTION = 54;
Integer FAILED_TO_CONNECT_TO_CHECK_POINT = 55;
Integer FAILED_TO_CONNECT_TO_GET_AZURE_DATA = 56;
Integer FAILED_TO_DOWNLOAD_AZURE_VPN_CONNECTION = 57;
Integer FAILED_TO_CREATE_IPSEC_TUNNELS_AZURE_VPN_CONNECTION = 58;
Integer FAILED_TO_GET_VTI_IP_GLOBAL_POOL = 59;
Integer FAILED_TO_CONNECT_TO_AZURE = 60;
Integer FAILED_TO_GET_BGP_ASN_GLOBAL_POOL = 61;
Integer GMS_BACKUP_RUNNING = 62;
Integer DUPLICATE_ASNS = 63;
Integer APPLIANCE_WAS_MANUALLY_ADDED = 64;
Integer INVALID_ASN = 65;
Integer CHECK_POINT_PAUSED = 66;
Integer ZSCALER_PAUSED = 67;
Integer AZURE_PAUSED = 68;
Integer LOOPBACK_POOL_FAIL_ALLOCATE = 69;
Integer APPLIANCE_DOES_NOT_SUPPORT_IPSLA_P2_METRICS = 70;
Integer APPLIANCE_DOES_NOT_SUPPORT_CUSTOM_BONDING = 71;
Integer APPLIANCE_DOES_NOT_SUPPORT_BEST_INTERNET_BREAKOUT = 72;
Integer INVALID_IPSEC_KEY_MATERIAL_LIFETIME = 73;
Integer APPLIANCE_SHELL_ACCESS_SETTING_OUT_OF_SYNC = 74;
Integer REMOTE_LOG_WEBSOCKET_NOT_CONNECTED = 75;
Integer FAILED_TO_CONNECT_TO_AWS = 76;
Integer AWS_TGNM_PAUSED = 77;
Integer FAILED_TO_GET_AWS_VTI_IP_GLOBAL_POOL = 78;
Integer PORTAL_BROADCAST_MESSAGE_WARNING = 79;
Integer STATS_COLLECTION_LAGGING_BEHIND = 80;
Integer AZURE_VWAN_DUPLICATE_ASN = 81;
Integer PORTAL_BAD_CONNECTIVITY = 82;
Integer UNSUPPORTED_DEPLOYMENT_MODE_FOR_VRF = 83;
Integer AWS_NO_INTERFACES_CONFIGURED = 84;
Integer AZURE_NO_INTERFACES_CONFIGURED = 85;
Integer AWS_NO_WAN_PUBLIC_IP = 86;
Integer AWS_RESERVED_ASN = 87;
Integer VRF_DNAT_DUP_IP = 88;
Integer AWS_ORCHESTRATION_FAILED = 89;
Integer AZURE_ORCHESTRATION_FAILED = 90;
Integer AZURE_MISSING_WAN_LABEL = 91;
Integer AWS_MISSING_WAN_LABEL = 92;
Integer ASN_UNAVAILABLE = 93;
Integer IPSEC_UDP_KEY_ROTATION_INCOMPLETE_PRE_ACTIVATION = 94;
Integer IPSEC_UDP_KEY_ROTATION_DELAYED = 95;
Integer UNSUPPORTED_APPLIANCE_VERSION_FOR_VRF = 96;
Integer UNABLE_TO_ACTIVATE_IPSEC_UDP_KEY = 97;
Integer ORCHESTRATION_IN_PROGRESS_FOR_MORE_THAN_24_HRS = 98;
Integer CUSTOM_CERTS_RESTART_REQUIRED = 99;
Integer ZSCALER_IPSLA_SOURCE_INTERFACE_NOT_CONFIGURED = 100;
Integer SERVICE_ORCH_MISSING_WAN_LABEL = 101;
Integer SERVICE_ORCH_NO_INTERFACES_CONFIGURED = 102;
Integer CLEARPASS_CONNECTION_INITIALIZATION_FAILURE = 103;
Integer CLEARPASS_SERVICE_UNREACHABLE = 104;
Integer CLEARPASS_INTEGRATION_PAUSED = 105;
Integer FAILED_TO_CONNECT_TO_STATS_COLLECTOR = 106;
Integer GMS_STATS_BACKUP_RUNNING = 107;
Integer FAILED_TO_CONNECT_TO_STATS_COLLECTORS = 108;
Integer STATS_COLLECTORS_DISK_USE_MAJOR = 109;
Integer HA_SYNC_COMMUNICATION_NOT_ENABLED = 110;
Integer ARUBACENTRAL_SITES_NO_LAT_LON = 111;
Integer FAILED_TO_CONNECT_TO_ARUBA_CENTRAL = 112;
Integer PORTAL_NETWORK_ISSUE = 113;
Integer ZSCALER_ORCHESTRATION_FAILED = 114;
Integer UNSUPPORTED_APPLIANCE_VERSION_FOR_DSC = 115;
Integer ZSCALER_GRE_NO_WAN_PUBLIC_IP = 116;
Integer LOCATION_BANDWIDTH_MISCONFIGURATION = 117;
Updated 11 months ago
