AOS 8 API FAQs
How to use API and which API to use for a particular task
In this section we will see what are some of the Frequently asked questions for AOS8 APIs. This section answers the following questions:
- What API to use
- How to use them
- In what sequence to use them (The importance of Sequential Configuration was explained earlier under REST API section.)
Updated 10 months ago
