AOS-CX Swagger UI
Utilizing the built-in API Documentation
Each AOS-CX device comes with a built-in with a graphical web interface to explore and try out the REST API with that particular device. This web interface is built on the Swagger framework, which allows the user to see all available API endpoints and the HTTP methods available for each endpoint. The Swagger web UI also allows users to test out the API by executing requests directly through the browser.
For devices supporting multiple versions of the REST API, there are UIs for each version. To access the Swagger interface(s): log into the switch's web interface and then click the Settings gear on the upper-right hand corner, and then click on the desired API version from the available options.
Accessing the Swagger interface from the AOS-CX Switch Web UI
Here is a tutorial for using the Swagger UI for the v1 API:
Updated 12 days ago
