Architecture III - Dedicated Data Center Layer 3 Spine/Leaf Topology - IBGP EVPN VXLAN with VSX
This workflow provisions switches in a Spine/Leaf topology using OSPF EVPN for the L3 fabric and L2 VXLAN with VSX based on the validated reference design. This workflow does not configure the centralized L3 gateway.
Workflow Prerequisites
- All prerequisites defined in Project Prerequisites
- Ensure the provided Ansible inventory file has been modified to suit your environment, according to the instructions in Inventory Setup:
- YAML Inventory File : inventory_spine_leaf.yml
- Excel Template File : dedicated_spine_leaf_ibgp_DCN_Settings.xlsx
- Example inventory using aoscx_dcn_plugin : dynamic_ibgp_spine_leaf_inventory.yml
- Spine switches = 2 AOS-CX switches
- Spine switches should be in a VSX pair and must support EVPN (8325/8400 required)
- Leaf switches = 4 or more AOS-CX switches
- Leaf switches should be in VSX pairs and must support EVPN/VXLAN (8325 required)
- Out-of-Band Management (OOBM) connections to the management ports on AOS-CX switches
- Ansible control machine should be reachable via each device's OOBM
Files Used
- Playbook : deploy_ibgp_evpn_vxlan.yml
- Inventory :
- Jinja2 Templates :
Workflow Walkthrough
Prior to executing the Ansible playbook, the environment must be in this initial state:
- Zone1-Spine<1/2> + Zone1-Rack1-Leaf<1a/1b> + Zone1-Rack3-Leaf<3a/3b> - These devices each have a default configuration with an IP address (DHCP/Static) assigned to the management interface. This IP address should match the the value of
ansible_hostfor each device in the inventory. - Zone1-Rack1-Leaf<1a/1b> - These devices are in a VSX pair with their physical links matching the values defined in the inventory
- Zone1-Rack3-Leaf<3a/3b> - These devices are in a VSX pair with their physical links matching the values defined in the inventory
The playbook will perform the following actions on every device in the inventory file using SSH:
- Generate a configuration based on the template file templates/eBGP/spine.j2 or templates/eBGP/leaf.j2 and values defined in the inventory
- Push the generated configuration to the device using the AOS-CX SSH Ansible module
aoscx_config - Enable 10g speed interface groups (if defined in the inventory using the AOS-CX SSH Ansible module
aoscx_config
The playbook will perform the following actions on every spine device in the inventory file
using SSH:
- Configure BGP neighbors and EVPN address families for every leaf's loopback IP address
The playbook will perform the following actions on every leaf device in the inventory file
using SSH:
- Configure BGP neighbors and EVPN address families for every spine's loopback IP address
- Create all VLANs defined as
server_vlansin the inventory - Create an EVPN instance and map VLANs defined in
server_vlans
Because of path requirements, you must run this workflow from the root level of the cloned repository:
ansible-playbook deploy_ibgp_evpn_vxlan.yml -i inventory_spine_leaf.ymlansible-playbook deploy_ibgp_evpn_vxlan.yml -i dynamic_ibgp_spine_leaf_inventory.ymlFinal Sample Configs
!Version ArubaOS-CX GL.10.04.0040
!export-password: default
hostname Zone1-Spine1
user admin group administrators password ciphertext AQBapeeuZ6Nw+Phok7vJbD6r75PivsY6o/r0QfxdpH1h3fQYYgAAACrisdLluFaTV+Fj1JfL0WsZPS8LBYsoE/N6qohz8bziNZQvKts2XD+d+Hgx+qrd64f4Htq7A/1mAvqetP90ljtfIOX27j/ZvVwqV6ewUQyQ7V7rFCe8BIXyVCXZD5QhqRdg
ssh server vrf mgmt
router ospf 1
router-id 192.168.1.11
area 0.0.0.0
vlan 1
interface mgmt
no shutdown
ip static 10.10.10.54/24
default-gateway 10.10.10.254
interface 1/1/23
no shutdown
mtu 9198
description rack3-Downlink
ip mtu 9198
ip address 192.168.2.13/31
ip ospf 1 area 0.0.0.0
ip ospf network point-to-point
interface 1/1/24
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.9/31
interface 1/1/27
no shutdown
mtu 9198
description rack1-Downlink
ip mtu 9198
ip address 192.168.2.1/31
interface 1/1/28
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.5/31
interface loopback 0
ip address 192.168.1.11/32
router bgp 65101
bgp router-id 192.168.1.11
neighbor 192.168.1.1 remote-as 65101
neighbor 192.168.1.1 update-source loopback 0
neighbor 192.168.1.2 remote-as 65101
neighbor 192.168.1.2 update-source loopback 0
neighbor 192.168.1.5 remote-as 65101
neighbor 192.168.1.5 update-source loopback 0
neighbor 192.168.1.6 remote-as 65101
neighbor 192.168.1.6 update-source loopback 0
address-family l2vpn evpn
neighbor 192.168.1.1 activate
neighbor 192.168.1.1 route-reflector-client
neighbor 192.168.1.1 send-community extended
neighbor 192.168.1.2 activate
neighbor 192.168.1.2 route-reflector-client
neighbor 192.168.1.2 send-community extended
neighbor 192.168.1.5 activate
neighbor 192.168.1.5 route-reflector-client
neighbor 192.168.1.5 send-community extended
neighbor 192.168.1.6 activate
neighbor 192.168.1.6 route-reflector-client
neighbor 192.168.1.6 send-community extended
exit-address-family
https-server rest access-mode read-write
https-server vrf mgmt!
hostname Zone1-Spine2
user admin group administrators password ciphertext AQBapW41EEHA+zskBXcBrm9Rr+euZNH+d4Q5BiGgeNrIvw1gYgAAANRxoQcfTTV7tma79JXNUOqrhv2y0xM21jrQxXeufK4O4aCwIfhuPJA7SPvno9iqnFJ9ehwrWSd5HdcyT1eb80glx6No9vqdDGKvOUfi6IOlDg6rcdaJcQWJ+tO7bZYVz5uz
ssh server vrf mgmt
router ospf 1
router-id 192.168.1.12
area 0.0.0.0
vlan 1
interface mgmt
no shutdown
ip static 10.10.10.55/24
interface 1/1/23
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.15/31
interface 1/1/24
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.11/31
interface 1/1/27
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.3/31
interface 1/1/28
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.7/31
ip address 192.168.1.12/32
router bgp 65101
bgp router-id 192.168.1.12
exit-address-family
!Version ArubaOS-CX GL.10.04.0020
hostname Zone1-Rack1-Leaf1a
user admin group administrators password ciphertext AQBapZ4yCW+QbkkvhYYoSS0WaqDVKw88SZxmgXHIxwMipV9EYgAAAMAuiAnGsQwvlI3bNifJth6elIQWykn7bGlAq+byxaItlAZQiZom10jqCFTailvy80jwvoNQdgLf6Ie6XIqed9Jzxk3X14GujvBxfL4XFHit14RQIALWT12Cj1o9TE55wRck
ssh server vrf mgmt
router ospf 1
area 0.0.0.0
vlan 1
vlan 11
name VLAN 11
description Server VLAN
evpn
vlan 11
rd auto
route-target export auto
route-target import auto
interface mgmt
no shutdown
ip static 10.10.10.56/24
system interface-group 1 speed 10g
!interface group 1 contains ports 1/1/1-1/1/12
system interface-group 3 speed 10g
!interface group 3 contains ports 1/1/25-1/1/36
interface lag 1
no shutdown
description VSX ISL LAG
no routing
vlan trunk native 1 tag
vlan trunk allowed all
lacp mode active
interface 1/1/1
no shutdown
no routing
vlan access 11
interface 1/1/31
no shutdown
description VSX KA
ip address 192.168.1.110/31
interface 1/1/32
no shutdown
mtu 9198
description VSX ISL
lag 1
interface 1/1/49
no shutdown
mtu 9198
description Spine-Uplink
ip mtu 9198
ip address 192.168.2.0/31
interface 1/1/50
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.2/31
ip address 192.168.1.1/32
interface loopback 1
ip address 192.168.100.1/32
interface vxlan 1
source ip 192.168.100.1
no shutdown
vni 11
vlan 11
vsx
inter-switch-link lag 1
role primary
keepalive peer 192.168.1.111 source 192.168.1.110
no split-recovery
router bgp 65101
neighbor 192.168.1.11 remote-as 65101
neighbor 192.168.1.11 update-source loopback 0
neighbor 192.168.1.12 remote-as 65101
neighbor 192.168.1.12 update-source loopback 0
neighbor 192.168.1.11 activate
neighbor 192.168.1.11 send-community extended
neighbor 192.168.1.12 activate
neighbor 192.168.1.12 send-community extended
exit-address-family
hostname Zone1-Rack1-Leaf1b
user admin group administrators password ciphertext AQBapd3Qg7OPKcjRayIQyuxOPabPIbT8bvU05pOk8sc+vAXyYgAAAGtM+A5APROROs6l56dpUdXic8SskYkcBHqp0rxFPtTqgmXoEzI21Mk5T3CR023fONvCpIZGpS4WUmReFVaiMR2XKnitYUhfkJLCK19Kl9uBL85jHFsthncP+X7/1q0bs/RG
ssh server vrf mgmt
router ospf 1
router-id 192.168.1.2
area 0.0.0.0
vlan 1
vlan 11
name VLAN 11
evpn
vlan 11
rd auto
interface mgmt
no shutdown
ip static 10.10.10.57/24
system interface-group 4 speed 10g
!interface group 4 contains ports 1/1/37-1/1/48
interface lag 1
no shutdown
no routing
lacp mode active
interface 1/1/31
no shutdown
description VSX KA
ip address 192.168.1.111/31
interface 1/1/32
no shutdown
mtu 9198
description VSX ISL
lag 1
interface 1/1/49
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.4/31
interface 1/1/50
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.6/31
ip address 192.168.1.2/32
ip address 192.168.100.2/32
interface vxlan 1
source ip 192.168.100.2
no shutdown
vni 11
vlan 11
vsx
role secondary
keepalive peer 192.168.1.110 source 192.168.1.111
no split-recovery
router bgp 65101
bgp router-id 192.168.1.2
exit-address-family
hostname Zone1-Rack3-Leaf3a
user admin group administrators password ciphertext AQBapd0lfpkb1JQ/PeM7VAdLaPTFpCWvep8Ky+FcXCXZQjzuYgAAABM81mz9TPm9mRgJCcs5jU94yotLIjlGFmqRd7CPrUe2I/hhn9STUUgq5O+A0aM94fIRyUcLkDyRzgAKnzk1HmDNlT1yWnxptSrdw2lh0C9wBxf/UpiQFZe+RU1NxIoXC18J
ssh server vrf mgmt
router ospf 1
router-id 192.168.1.5
area 0.0.0.0
vlan 1
vlan 11
name VLAN 11
evpn
vlan 11
rd auto
interface mgmt
no shutdown
ip static 10.10.10.60/24
interface lag 1
no shutdown
no routing
lacp mode active
interface 1/1/31
no shutdown
description VSX KA
ip address 192.168.1.112/31
interface 1/1/32
no shutdown
mtu 9198
description VSX ISL
lag 1
interface 1/1/49
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.8/31
interface 1/1/50
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.10/31
ip address 192.168.1.5/32
ip address 192.168.100.5/32
interface vxlan 1
source ip 192.168.100.5
no shutdown
vni 11
vlan 11
vsx
role primary
keepalive peer 192.168.1.113 source 192.168.1.112
no split-recovery
router bgp 65101
bgp router-id 192.168.1.5
exit-address-family
hostname Zone1-Rack3-Leaf3b
user admin group administrators password ciphertext AQBapaHRO1zdYAmv8jyi6BEy2EdGo7mXog4SaUdBnB6VBVmrYgAAAMswpUXLpjUGA0QadW9dCf7EgZkDyT6oT740N0z8ey2PTAAz8DT02vzpz1sAo27jMoqJ3YCXA0bW05qG+CWqweUfanbUEccqyrEu8SpcQjUoYdHYFZFHFtniXxA7d9wFijPV
ssh server vrf mgmt
router ospf 1
router-id 192.168.1.6
area 0.0.0.0
vlan 1
vlan 11
name VLAN 11
evpn
vlan 11
rd auto
interface mgmt
no shutdown
ip static 10.10.10.61/24
interface lag 1
no shutdown
no routing
lacp mode active
interface 1/1/1
no shutdown
no routing
vlan access 11
interface 1/1/31
no shutdown
description VSX KA
ip address 192.168.1.113/31
interface 1/1/32
no shutdown
mtu 9198
description VSX ISL
lag 1
interface 1/1/49
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.12/31
interface 1/1/50
no shutdown
mtu 9198
ip mtu 9198
ip address 192.168.2.14/31
ip address 192.168.1.6/32
ip address 192.168.100.6/32
interface vxlan 1
source ip 192.168.100.6
no shutdown
vni 11
vlan 11
vsx
role secondary
keepalive peer 192.168.1.112 source 192.168.1.113
no split-recovery
router bgp 65101
bgp router-id 192.168.1.6
exit-address-family
https-server vrf mgmtUpdated 3 months ago
