HomeGuidesAPI Reference
GuidesAPI ReferenceGitHubAirheads Developer CommunityLog In
Using the Network Analytics Engine
Installing Scripts and Creating Agents
Installing NAE Scripts
Using the switch's web UI to install NAE scripts
  1. In your web browser, navigate to the switch's IP address or hostname, making sure to use HTTPS:
1913
Landing message and page for AOS-CX web UI
  1. Log in with the username and password of the user possessing administrator privileges:
506
Login context
  1. Click on Analytics in the menu on the left-hand side:
250
Left-side menu pane
  1. Click on the title of the Scripts tile:
410
Scripts tile on the Agent dashboard page
At the top of the window, click the cloud ASE icon towards the right:
2941
ACCEPT the license agreement:
3434
License agreement
  1. Wait for the window to be populated with the Aruba-curated scripts. Only those that are tagged for the platform you are using will be shown. Select the appropriate script to monitor the desired values, and click INSTALL:
1630
ASE listing of available scripts compatible with the particular switch's platform
Uploading a script from your local machine
  1. On the Analytics page, click the title in the Scripts tile:
410
The Scripts tile on the Agent dashboard page
At the top of the window, click the UPLOAD button towards the left:
2941
Upload button, among other buttons
  1. Navigate to the location containing the script (which should be a Python file with the appropriate .py extension) and select it:
950
File-selector prompt
  1. Follow the upload prompt and click NEXT:
2283
Upload confirmation page
Creating an Agent
After the script has been installed on the system, to initiate the monitoring process an Agent needs to be created.
  1. Select the script in the Scripts window from which you want to create an agent and click + CREATE AGENT:
1629
Scripts page on which agents can be created
  1. In the "Create Agent" form, name the agent (nomenclature requirements shown in red), fill in all mandatory fields (i.e. those without default values) and optional fields, and click CREATE. This will create your agent which will begin monitoring immediately.
1535
Agent creation form
Upon creating the agent you are brought to the Agents list page, where you can see your newly created agent among all the other agents.
1625
Agents page showing all existing agents
From this page, you can click on the name of an agent in order to view its Agent Details page and graph.
1625
Agent details page
Model Specific Differences
Switch Model
Max # of Scripts
Max # of Agents
Max # of Monitors
Max Script Size
of Days Stored in Database*
Amount of Disk Storage Allocated
8400
50
100
300
256KB
400
18GB
8360
25
50
150
256KB
400
9GB
8325
25
50
150
256KB
400
9GB
8320
25
50
150
256KB
400
9GB
6400
10
10
130
256KB
45
3.1GB
6300
10
10
130
256KB
45
3.1GB
6200
10
10
130
256KB
15
1GB
Amount of days listed is the maximum as long as data does not go over the above amount of disk storage allocated to NAE for that particular model. If the disk storage allocated has reached it's max, NAE will remove the oldest data in order to make space for newer data added.
NAE Scripts to Start with
Fault Finder
  • Identifies general faults and helps protect against network loops and issues caused by defective peripherals.
Hardware Device Health
  • Minimum firmware version 10.04 required. Monitors overall hardware device health using the Temperature Sensor, Fan Sensor, and Fault Finder scripts.
Software Device Health
  • Minimum firmware version 10.04 required. Monitors overall software device health using the MAC Count, MAC Decrease Rate, Fault Finder, Daemon Resource, and VSX Health scripts.
What’s Next
