AOS-CX Ansible Collection
Using the AOS-CX collection
There are two approaches to using the AOS-CX modules: role and collection. A guide for the latter is detailed here. For the alternative method, see the instructions for using the AOS-CX Ansible Roles under Additional Resources
What is an Ansible collection?
In Ansible, a collection is used to bundle up and distribute Ansible content, including items such as playbooks, roles, modules, and plugins.
Installing the CollectionIf you're looking for instructions to install the HPE Aruba Networking AOS-CX Ansible Collection, check out the section Installing the HPE Aruba Networking AOS-CX Collection.
AOS-CX Module Support and Compatibility
All of HPE Aruba Networking's Ansible modules can be run with both Ansible Engine and the Ansible GUIs (Ansible Automation Platform and AWX). The sole requirement is Ansible version 2.9.0 or later and the pyaoscx v2 Python package.
| Module | 8400 | 8360 | 8325 | 8320 | 6400-6000 | 4100i | 10000 | 9300 |
| aoscx_acl | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_acl_interface | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_acl_vlan | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_backup_config | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_banner | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_boot_firmware | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_checkpoint | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_command | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_config | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_dns | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_facts | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_interface | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | |
| aoscx_l2_interface | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_l3_interface | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_mac | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_ospf_area | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_ospf_interface | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_ospf_router | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_ospf_vlink | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_ospfv3_area | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_ospfv3_router | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_ospfv3_vlink | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_poe | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_qos | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_qos_cos | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_qos_dscp | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_queue | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_queue_profile | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_queue_profile_entry | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_static_mac | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_static_route | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_system | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_upload_config | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_upload_firmware | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_vlan | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_vlan_interface | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_vrf | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| aoscx_vsx | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
| Platform | Firmware |
| 8400 | XL.10.04.001 and later |
| 8360 | LL.10.06.001 and later |
| 8325 | GL.10.04.001 and later |
| 8320 | TL.10.04.001 and later |
| 6400-6300 | FL.10.04.001 and later |
| 6200 | FL.10.04.001 and later |
| 6100 | PL.10.06.001 and later |
SSH/CLI Modules
All of our modules in the AOS-CX collection are written to use REST API for connection and configuration, however we do have an option to use SSH as a connection method to execute CLI commands directly onto the switch. The modules aoscx_config and aoscx_command use SSH to connect to the AOS-CX switch to execute CLI commands. These modules can be used in addition to or instead of the REST API modules provided in the collection.
To use the SSH/CLI modules aoscx_config and aoscx_command, SSH access must be enabled on your AOS-CX device. It is enabled by default.
- If necessary, re-enable SSH access on the device with the following command:
switch(config)# ssh server vrf mgmt
The control node's known_hosts file must contain the target device's public key. Alternatively, host key checking by the control node may be disabled, although this is not recommended. To disable host key checking, modify the ansible.cfg file (located by default at /etc/ansible/ansible.cfg) to include:
host_key_checking=False
[defaults]
host_key_checking=FalseLimitations and Notes
When using the SSH modules to execute "show" commands, it's important to keep in mind that the output of the executed CLI commands are inherently hidden during Ansible's execution. Therefore it's best practice to save the output of any "show" command to a variable using Ansible's register capabilities and outputting the result. Alternatively, you can run the ansible-playbook command in verbose by adding -v to the command to output during runtime. See the below output for each method:
ansible-control-machine$ansible-playbook show_vlan_debug.yml -i hosts.yml
PLAY [all] *********************************************************************
TASK [Gathering Facts] *********************************************************
ok: [aoscx_1]
TASK [Execute show vlan on the switch and register] ****************************
ok: [aoscx_1]
TASK [Output registered variable] **********************************************
ok: [aoscx_1] => {
"show_vlan_output": {
"changed": false,
"failed": false,
"stdout": [
"------------------------------------------------------------------------------------------------------------------\nVLAN Name Status Reason Type Interfaces \n------------------------------------------------------------------------------------------------------------------\n1 DEFAULT_VLAN_1 up ok default 1/1/2-1/1/28\n11 VLAN11 down no_member_port static \n12 VLAN12 down no_member_port static \n13 VLAN13 down no_member_port static \n255 VLAN255 down no_member_forwarding static 1/1/1,lag220\n4000 VLAN4000 down no_member_port static"
"stdout_lines": [
"VLAN Name Status Reason Type Interfaces ",
"1 DEFAULT_VLAN_1 up ok default 1/1/2-1/1/28",
"11 VLAN11 down no_member_port static ",
"12 VLAN12 down no_member_port static ",
"13 VLAN13 down no_member_port static ",
"255 VLAN255 down no_member_forwarding static 1/1/1,lag220",
"4000 VLAN4000 down no_member_port static"
PLAY RECAP *********************************************************************
aoscx_1 : ok=3 changed=0 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
ansible-control-machine$cat show_vlan_debug.yml
- hosts: all
collections:
- arubanetworks.aoscx
vars:
ansible_connection: network_cli
tasks:
- name: Execute show vlan on the switch and register
aoscx_command:
commands: ['show vlan']
register: show_vlan_output
- name: Output registered variable
debug:
var: show_vlan_outputansible-control-machine$ansible-playbook show_vlan.yml -i hosts.yml -v
Using /etc/ansible/ansible.cfg as config file
ok: [aoscx_1]
TASK [Execute show vlan on the switch] *****************************************
ok: [aoscx_1] => {"changed": false, "stdout": ["------------------------------------------------------------------------------------------------------------------\nVLAN Name Status Reason Type Interfaces \n------------------------------------------------------------------------------------------------------------------\n1 DEFAULT_VLAN_1 up ok default 1/1/2-1/1/28\n11 VLAN11 down no_member_port static \n12 VLAN12 down no_member_port static \n13 VLAN13 down no_member_port static \n255 VLAN255 down no_member_forwarding static 1/1/1,lag220\n4000 VLAN4000 down no_member_port static"], "stdout_lines": [["------------------------------------------------------------------------------------------------------------------", "VLAN Name Status Reason Type Interfaces ", "------------------------------------------------------------------------------------------------------------------", "1 DEFAULT_VLAN_1 up ok default 1/1/2-1/1/28", "11 VLAN11 down no_member_port static ", "12 VLAN12 down no_member_port static ", "13 VLAN13 down no_member_port static ", "255 VLAN255 down no_member_forwarding static 1/1/1,lag220", "4000 VLAN4000 down no_member_port static"]]}
aoscx_1 : ok=2 changed=0 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
ansible-control-machine$cat show_vlan.yml
- hosts: all
collections:
vars:
tasks:
aoscx_command:
commands: ['show vlan']- The default command timeout is 30 seconds. If a command takes more than 30
seconds to execute, the task will time out.- If you regularly encounter the
command timeout triggered, timeout value is 30 secserror, consider setting the environment variable
ANSIBLE_PERSISTENT_COMMAND_TIMEOUTto a greater value. See Ansible documentation here.
Inventory Setup
In addition to installing the AOS-CX collection, you must also add any AOS-CX hosts to the Ansible inventory. For each AOS-CX switch, the following inventory variables must be defined:
ansible_host: IP address of the switch inA.B.C.Dformat; for IPv6 hosts use a string and enclose the IP address in square brackets (e.g.'[2001::1]')ansible_user: Username for the switch in plaintextansible_password: Password for the switch in plaintextansible_network_os: Must always be set toarubanetworks.aoscx.aoscxansible_connection: Set toarubanetworks.aoscx.aoscxto use REST API modules,network_clito use SSH/CLI modules, andhttpapifor legacy REST API method.- See below for info on using both REST API modules and SSH/CLI modules on a host
ansible_acx_no_proxy: May be set to eitherTrueorFalsedepending on whether Ansible should bypass environment proxies when connecting to the switch.ansible_aoscx_validate_certs: Set toTrueorFalsedepending if Ansible should bypass validating certificates to connect to AOS-CX. Only required whenansible_connectionis set toarubanetworks.aoscx.aoscxansible_aoscx_use_proxy: Set toTrueorFalsedepending if Ansible should bypass environment proxies to connect to AOS-CX. Only required whenansible_connectionis set toarubanetworks.aoscx.aoscx.ansible_httpapi_use_ssl: Must always beTrueas AOS-CX uses port 443 for REST. Only required whenansible_connectionis set tohttpapi.ansible_httpapi_validate_certs: May be set to eitherTrueorFalsedepending on whether Ansible should attempt to validate SSL certificates on the device. Only required whenansible_connectionis set tohttpapi.
Example inventories for REST API (each with one host)
INI
aoscx_1 ansible_host=10.0.0.1 ansible_user=admin ansible_password=password ansible_network_os=arubanetworks.aoscx.aoscx ansible_connection=arubanetworks.aoscx.aoscx ansible_aoscx_validate_certs=False ansible_aoscx_use_proxy=False ansible_acx_no_proxy=TrueYAML
all:
hosts:
aoscx_1:
ansible_host: 10.0.0.1
ansible_user: admin
ansible_password: password
ansible_network_os: arubanetworks.aoscx.aoscx
ansible_connection: arubanetworks.aoscx.aoscx # REST API via pyaoscx connection method
ansible_acx_no_proxy: True
ansible_aoscx_validate_certs: False
ansible_aoscx_use_proxy: FalseExample inventories for SSH/CLI (each with one host)
INI
aoscx_1 ansible_host=10.0.0.1 ansible_user=admin ansible_password=password ansible_connection=network_cli ansible_network_os=arubanetworks.aoscx.aoscxYAML
all:
hosts:
aoscx_1:
ansible_user: admin
ansible_connection: network_cli # SSH connection method
ansible_network_os: arubanetworks.aoscx.aoscxExample Playbook
Note the inclusion of the collection with collections: and - ...:
- hosts: all
collections:
tasks:
- name: Create L3 Interface 1/1/3
aoscx_l3_interface:
interface: 1/1/3
description: Uplink_Interface
ipv4: ['10.20.1.3/24']
ipv6: ['2001:db8::1234/64']Using Both REST API and SSH/CLI Modules on a Host
To use both REST API and SSH/CLI modules on the same host, you must create separate plays such that each play uses either only REST API modules or only SSH/CLI modules. A play cannot mix and match REST API and SSH/CLI module calls.
In each play, ansible_connection must possess the appropriate value according to the modules used. If the play uses REST API modules, that value should be arubanetworks.aoscx.aoscx. If the play uses SSH/CLI modules, that value should be network_cli.
A recommended approach to successfully using both types of modules for a host is as follows:
- Set the host variables such that Ansible will connect to the host using REST API, like seen above.
- In the playbook, in each play wherein the SSH/CLI modules are used, set the
ansible_connectiontonetwork_cli.
The inventory should look something like this:
all:
hosts:
aoscx_1:
ansible_user: admin
ansible_aoscx_use_proxy: Falseand the playbook like this (note how the second play, which uses the SSH/CLI module aoscx_command, sets the ansible_connection value accordingly):
- hosts: all
collections:
tasks:
- name: Create VLAN 300 with description and name
aoscx_vlan:
vlan_id: 300
description: This is VLAN 300
- hosts: all
collections:
vars:
tasks:
aoscx_command:
commands: ['show vlan']Updated 3 months ago
