Deploying Devices
Provisioning devices with groups, templates, and variables
Let's start with the anterior workflow, the deployment of devices with Classic Central. The example workflow illustrated below consists of four steps:
- Creating a new template group
- Uploading a template to the group
- Adding variables for the devices
- Assigning the devices to the group
Warning
Template mode is not available with AOS-10. The workflow highlighted here is for AOS-8 based devices.
Note
This is an example workflow; as such it is intentionally prescriptive and tailored to fit a certain scenario. The Ansible modules used in this workflow each provide additional capabilities to suit various deployment scenarios. Instead of following the prescribed steps, you could alternatively, for example:
i. Clone an existing template group
ii. Update an existing template
iii. Update or replace variables for devices
For more information on the capabilities of each module, please look at the module documentation in our GitHub repository. The documentation for each module covers the module's capabilities in depth.
Workflow Prerequisites
- Classic Central Ansible Collection installed:
ansible-galaxy collection install arubanetworks.aruba_central
- Devices imported beforehand into Classic Central by Activate
Creating a Group
Firstly, we'll create a template group. This task uses the central_groups module which is used to create a template group for wired and wireless devices.
- name: Create a new group
central_groups:
action: create
group_name: new-group
group_attributes:
group_password: admin@12345
template_group:
wired: True
wireless: True
The attributes
wired: Trueandwireless: Truein thetemplate_groupdictionary indicate that the created group is a template group using templates for both wired and wireless devices.
Adding a Template
Step two is to upload a template to the group. In order to do this, we'll create a template file and write an Ansible task to upload it.
An example template for an AOS-Switch device is shown below. Note that some information in the template, namely the SHA-1 hash of the admin user's password, has been redacted.
AOS-S template
%_sys_template_header%
hostname "%_sys_hostname%"
%_sys_module_command%
no cwmp enable
include-credentials
password manager user-name "admin" sha1 "xxxxxxe75asddfdaf415cxxxxxxfe21axxxx"
timesync ntp
ntp unicast
ntp server-name "time.google.com" iburst
ntp enable
time timezone -420
ip client-tracker
interface 1
name "To_SW2"
exit
interface 24
name "Uplink_BGW"
exit
snmp-server community "Aruba123" unrestricted
snmpv3 engineid "%_sys_snmpv3_engineid%"
vlan 1
name "Management"
untagged %_sys_vlan_1_untag_command%
%if _sys_use_dhcp=1%
ip address dhcp-bootp
%endif%
%if _sys_use_dhcp=0%
ip address %_sys_ip_address% %_sys_netmask%
%endif%
ipv6 enable
ipv6 address dhcp full
exit
vlan 20
name "Employee"
tagged 1-2,5-9,24
no ip address
exit
vlan 30
name "Guest"
tagged 1-2,5-9,24
no ip address
exit
All non-templated, parametrized CLI text in the template must exactly match the running configuration syntax. As such, the indentation of CLI text in the template should match the indentation in the running configuration. All CLI text in the template is case-sensitive.
A recommended best practice is to perform validation of the configuration input on the device CLI prior to adding it to the template.
In addition to creating the template, we also need to create the task to upload it. This task uses the central_templates module to upload a template text file by specifying its local path:
- name: Upload a new template file and create a new template for a given device type
central_templates:
action: create
template_name: aos-sw-temp
device_type: ArubaSwitch
version: ALL
model: ALL
local_file_path: /home/admin/sw_template.txt
The examples shown for the above step apply to AOS-S devices. You can upload templates for AOS-CX switches and access points as well. Module documentation, as previously mentioned, and specifically that for the
central_templatesmodule, will provide the pertinent information.
Access Point Template
Template mode is not supported with AOS-10. Sample template below is for an AOS-8 device.
As part of this workflow, we're also deploying an access point. An access point template is provided below (again, with certain values censored); it is left as an exercise to the reader to create the additional task to upload this template!
version 8.6.0.0-8.6.0
virtual-controller-country US
virtual-controller-key fdxxxxxxzzzzzzyyyyyda0542c660a35xxxxxxxxx8
name %vc_name%
terminal-access
openflow-server host internal2-ofc.central.arubanetworks.com tcp-port 443
openflow-server tls-enable
ntp-server time.google.com
clock timezone Pacific-Time -08 00
clock summer-time PDT recurring second sunday march 02:00 first sunday november 02:00
rf-band all
ams-identity xxxxxxxx689723993xxxxxxxxx5bbfaxx
report-rssi-to-central unassociated-and-associated-clients
allow-new-aps
allowed-ap aa:aa:aa:aa:aa:aa
allowed-ap bb:bb:bb:bb:bb:bb
allowed-ap cc:cc:cc:cc:cc:cc
allowed-ap dd:dd:dd:dd:dd:dd
allowed-ap ee:ee:ee:ee:ee:ee
arm
wide-bands none
a-channels 52,56,60,64
g-channels 6
min-tx-power 9
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode default-access
channel-quality-aware-arm-disable
client-aware
scanning
rf dot11g-radio-profile
max-distance 0
max-tx-power 9
min-tx-power 6
disable-arm-wids-functions off
free-channel-index 40
rf dot11a-radio-profile
max-distance 0
max-tx-power 18
min-tx-power 12
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
hash-mgmt-password
hash-mgmt-user admin password hash 11111111111111111f1c4xxxxxxxxxxxxxeb2bd3f632xxf29e35xxxxxx08ezzzz
wlan access-rule default_#guest#_
index 0
rule alias licdn.com match tcp 443 443 permit
rule alias twimg.com match tcp 443 443 permit
rule alias bam.nr-data.net match tcp 443 443 permit
rule alias js-agent.newrelic.com match tcp 443 443 permit
rule alias symcb.com match tcp 80 80 permit
rule alias symcd.com match tcp 80 80 permit
rule alias digicert.com match tcp 80 80 permit
wlan access-rule default_wired_port_profile
index 1
rule any any match any any any permit
wlan access-rule wired-SetMeUp
index 2
rule any any match udp 67 68 permit
rule any any match udp 53 53 permit
wlan access-rule %ssid_name%
utf8
index 5
wlan ssid-profile %ssid_name%
enable
index 1
type employee
essid %ssid_name%
utf8
wpa-passphrase xxxxxx1111xxxzz1111fb2bzzzzz1880ba4fxxxxx1aca2222
opmode wpa2-psk-aes
max-authentication-failures 0
vlan 20
auth-server InternalServer
rf-band 5.0
captive-portal disable
dtim-period 1
broadcast-filter arp
openflow-enable
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
auth-survivability cache-time-out 24
dpi
url-visibility
wlan auth-server AS2_#guest#_
radsec port 443
ip naw2-elb.cloudguest.central.arubanetworks.com
port 1812
acctport 1813
timeout 20
nas-id 7xxxaaeaa1-xxcx-111z-11x1-0xxxxxx99zz
rfc3576
wlan auth-server AS1_#guest#_
radsec
ip naw2.cloudguest.central.arubanetworks.com
port 1812
acctport 1813
timeout 20
nas-id 77xxxaaeaa1-zzcx-111z-11x1-0xxzzzxx99zz
rfc3576
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
auto-whitelist-disable
https
wlan external-captive-portal default_#guest#_
server naw2.cloudguest.central.arubanetworks.com
port 443
url "/portal/scope.cust-xxxxxxxx11111111zzzzzzzzz1111111/default/capture"
auth-text ""
https
ids
wireless-containment none
wired-port-profile wired-SetMeUp
switchport-mode access
allowed-vlan all
native-vlan guest
no shutdown
access-rule-name wired-SetMeUp
speed auto
duplex auto
no poe
type guest
no dot1x
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type employee
no dot1x
enet0-port-profile default_wired_port_profile
uplink
preemption
enforce none
failover-internet-pkt-lost-cnt 10
failover-internet-pkt-send-freq 30
failover-vpn-timeout 180
airgroup
disable
airgroupservice airplay
disable
description AirPlay
airgroupservice airprint
disable
description AirPrint
airgroupservice DIAL
disable
airgroupservice remotemgmt
disable
airgroupservice AmazonTV
disable
airgroupservice allowall
disable
airgroupservice googlecast
disable
airgroupservice itunes
disable
airgroupservice sharing
disable
airgroupservice chat
disable
airgroupservice "DLNA Print"
disable
airgroupservice "DLNA Media"
disable
clarity
inline-sta-stats
inline-auth-stats
inline-dhcp-stats
inline-dns-stats
cluster-security
allow-low-assurance-devices
per-ap-settings %_sys_lan_mac%
hostname %hostname%
zonename %zonename%
Setting Variables
The next step of this workflow is to upload device-specific variables so that they can be used to render the template into actual concrete running configurations to be applied to the devices.
Unlike a template, which belongs to a group, variables are associated with a device, irrespective of which group to which the device belongs.
There are two approaches to adding variables:
i. Adding variables for one device by specifying its serial number
ii. Adding variables for multiple devices using a JSON file wherein each device has a dictionary containing its variables and values.
Because this workflow performs an initial rollout for multiple devices, it makes sense that we employ the second approach to upload variables for our devices.
The example JSON file shown below is a variables file containing variable definitions for an AOS-S switch and an access point. Note that each key in the overarching dictionary is a device's serial number, and the corresponding value is a dictionary containing the device's variable definitions in a key-value format. Like with the example templates before, certain values here have been redacted.
"CNXXXXXXXD": {
"_sys_serial": "CNXXXXXXXD",
"_sys_lan_mac": "aa:aa:aa:aa:aa:aa",
"_sys_gateway": "",
"_sys_hostname": "SW1",
"_sys_ip_address": "",
"_sys_module_command": "module 1 type jl261a",
"_sys_netmask": "",
"_sys_oobm_command": "",
"_sys_snmpv3_engineid": "00:00:00:0b:00:00:b8:83:03:d5:fc:a0",
"_sys_stack_command": "",
"_sys_template_header": "; JL261A Configuration Editor; Created on release #WC.16.08.0003\n; Ver #14:27.6f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:04\n",
"_sys_use_dhcp": "1",
"_sys_vlan_1_tag_command": "",
"_sys_vlan_1_untag_command": "1-28",
"community": "Aruba123",
"dhcp": "true",
"dns": "1.1.1.1",
"gw": "10.1.1.1",
"ip": "10.1.1.14",
"mask": "255.255.255.0",
"ntp_server": "time.google.com",
"test": "0",
"timezone_seconds": "-420"
"CNYYYYYYYD": {
"_sys_lan_mac": "bb:bb:bb:bb:bb:bb",
"_sys_serial": "CNYYYYYYYD",
"ssid_name": "Employee-test",
"vc_name": "Instant-AP-VC",
"hostname": "IAP-1",
"zonename": "Ground-Floor"
The variables
_sys_lan_macand_sys_serialare mandatory and must be included in every template and in every device's variable definitions.
In addition to defining our variables file, we'll need a task to upload the variables file. This task uses the central_variables module:
- name: Create/set template variables for all/multiple devices using a JSON file central_variables:
action: create_all
local_file_path: /home/admin/variables.json
Moving Devices to a Group
Lastly, to provision our devices, we'll move them into the group that now contains the appropriate templates. The act of moving devices takes them out of one group and places them in another. When the device is placed in a template group with an applicable template, the template is automatically applied, and the variables associated with the device are used in conjunction with this template to seamlessly deploy the resultant running configuration to the device.
When a device is imported into Classic Central, it is automatically placed in the default group.
In general, it is recommended that a device is moved to a newly created group after the group contains the applicable template and all the variables parametrized in the template have been defined for the device.
This task example uses the central_devices module to move devices to a group using their serial numbers.
- name: Move devices to a group
central_devices:
action: move_devices
device_serial_list:
- CNXXXXXXXX
- CNXXXXXXYY
Success and Debrief!
And that's it! If you've followed this tutorial as directed, your playbook should contain five tasks.
To summarize briefly, the requisite conditions for successful device deployment are that :
- a template group for the device type (i.e. wired or wireless) exists
- the template group contains a template applicable to the device
- the device has variables associated with it
- the device is situated in the template group
Updated 2 months ago
