PyCentral Features
As part of the PyCentral v1 release, some new features have been added to simplify and enhance your automation experience.
Per Second Rate Limit
Whenever the per-second API rate limit is reached for the Central account, PyCentral pauses script execution for 2 seconds for the rate limit to be reset before continuing execution. It will also log the following message to the terminal to indicate the same to the user
Per-second rate limit reached. Adding 2 seconds interval and retrying.
Per Day Rate Limit
When the per-day API rate limit is exhausted for the Central account, PyCentral will log a message indicating that and exit from executing the script.
"Per-day rate limit of 5000 is exhausted. Please check Central UI to see when the daily rate limit quota will be reset
Updated 3 months ago
