Monitoring-AOS Switch Streaming Event
This section provides information on the AOS Switch based streaming events within the Monitoring topic.
Protocol Buffer messages for AOS Switches in Monitoring Topic
message Interface
enum Duplex
HALF = 1;
FULL = 2;
AUTO = 3;
enum IntfType
ETHERNET = 1;
LOOPBACK = 2;
VLAN = 3;
TUNNEL = 4;
PORT_CHANNEL = 5;
STANDBY = 6;
BRIDGE = 7;
SPLIT = 8;
STACK = 9;
MGMT = 10;
NONE = 11;
enum SpeedType
SPEED_INVALID = 0;
SPEED_AUTO = 1;
SPEED_10 = 2;
SPEED_100 = 3;
SPEED_1000 = 4;
SPEED_10000 = 5;
enum PortType
PT_RJ45 = 0;
PT_GBIC = 1;
PT_SERIAL = 2;
PT_USB = 3;
PT_X2 = 4;
enum PoeSupport
NA = 0;
SUPPORTED = 1;
NOT_SUPPORTED = 2;
enum StateDownReason
UNINITIALIZED = 1;
WAITING_FOR_LINK = 2;
ADMIN_INTERFACE_DOWN = 3;
MODULE_MISSING = 4;
MODULE_UNRECOGNIZED = 5;
MODULE_UNSUPPORTED = 6;
MODULE_INCOMPATIBLE = 7;
MODULE_FAULT = 8;
GROUP_SPEED_MISMATCH = 9;
LANES_SPLIT = 10;
LANES_NOT_SPLIT = 11;
INVALID_MTU = 12;
INVALID_SPEEDS = 13;
AUTONEG_NOT_SUPPORTED = 14;
AUTONEG_REQUIRED = 15;
INTERFACE_ABSENT = 16;
PHYSICAL_INTERFACE_FAILED = 17;
PSPO_ENABLEMENT_LAYER_DOWN = 18;
CARD_INTERFACE_ERRORS = 19;
INTERFACE_OK = 20;
enum VlanModes
ACCESS = 1;
NATIVE_TAGGED = 2;
NATIVE_UNTAGGED = 3;
optional Action action = 1 [default = UPDATE]; // Mandatory
optional string device_id = 2; // Mandatory
optional MacAddress macaddr = 3; // Mandatory
optional Status status = 4 [default = UP]; // Mandatory
optional IpAddress ipaddr = 5;
optional Duplex duplex_mode = 6; // This field will be present only for IAP Interface alone.
optional string name = 7; // Mandatory
optional string port_number = 8; // Mandatory
optional IntfType type = 9; // Mandatory
optional string mode = 10;
optional uint32 vlan = 11;
optional PoeSupport has_poe = 12 [default = NA]; // This field is applicable for switches alone.
optional Status poe_state = 13 [default = UP];
optional Status oper_state = 14 [default = UP]; // Mandatory
optional Status admin_state = 15 [default = UP]; // Mandatory
optional SpeedType speed = 16; // Mandatory
optional uint32 mux = 17;
optional uint32 trusted = 18;
optional string slot = 19;
optional PortType phy_type = 20;
optional string sub_type = 21;
repeated uint32 allowed_vlan = 22;
optional uint32 native_vlan = 23;
optional bool vsx_enabled = 24;
optional StateDownReason state_down_reason = 25;
optional VlanModes vlan_mode = 26;
message InterfaceStats
optional string device_id = 1; // Mandatory
optional MacAddress macaddr = 2; // Mandatory
optional uint32 timestamp = 3; // Mandatory
optional uint64 tx_bytes = 4; // Mandatory
optional uint64 rx_bytes = 5; // Mandatory
optional uint32 power_consumption = 6;
optional uint64 in_errors = 7;
optional uint64 out_errors = 8;
optional uint64 in_discards = 9;
optional uint64 out_discards = 10;
optional uint64 in_packets = 11;
optional uint64 out_packets = 12;
optional uint32 in_other_err = 13;
optional uint64 in_multicast_pkt = 14;
optional uint64 in_broadcast_pkt = 15;
optional uint64 in_unicast_pkt = 16;
optional uint64 out_multicast_pkt = 17;
optional uint64 out_broadcast_pkt = 18;
optional uint64 out_unicast_pkt = 19;
optional uint64 in_fcs = 20;
optional uint64 in_alignment = 21;
optional uint32 out_excessive_collision = 22;
optional uint64 in_jabbers = 23;
optional uint64 in_fragmented = 24;
optional uint32 in_giant = 25;
optional uint32 in_runt = 26;
optional uint64 out_collision = 27;
optional uint32 out_late_collision = 28;
optional uint32 out_deferred = 29;
message DeviceNeighbours
optional string port = 3; // Mandatory
optional string remote_device_id = 4;
optional string remote_port = 5;
optional string remote_port_number = 6;
optional string vlan_id = 7;
//The following messages are statistics protobufs
message DeviceStats
optional uint32 timestamp = 2; // Mandatory
optional uint64 uptime = 3; // Mandatory
optional uint32 cpu_utilization = 4; // Mandatory for IAP and HP switches.
optional uint64 mem_total = 5; // Mandatory for IAP and HP switches.
optional uint64 mem_free = 6; // Mandatory for IAP and HP switches.
optional uint32 power_consumption = 7;
optional uint32 fan_speed = 8;
optional uint32 temperature = 9;
optional Status fan_status = 10;
optional uint32 max_power = 11;
optional uint32 poe_consumption = 12;
optional uint32 poe_budget = 13;
optional uint64 mem_utilization = 14;
message SwitchStack
enum StackTopology
STANDALONE = 1;
CHAIN = 2;
RING = 3;
MESH = 4;
PARTIAL_MESH = 5;
UNKNOWN = 6;
enum StackPolicy
STACK_SPLIT_UNKNOWN = 0;
STACK_SPLIT_ONE_FRAGMENT_UP = 1;
STACK_SPLIT_ALL_FRAGMENTS_UP = 2;
optional string stack_id = 2;
optional Status status = 3 [default = UP]; // Mandatory
optional StackTopology topology = 4;
optional StackPolicy policy = 5;
optional string firmware_version = 6;
optional uint32 vsf_domain_id = 7;
message Switch
enum StackMemberRole
UNKNOWN = 1;
COMMANDER = 2;
STANDBY = 3;
MEMBER = 4;
optional string serial = 2; // Mandatory
optional string name = 3; // Mandatory
optional MacAddress macaddr = 4; // Mandatory
optional string model = 5; // Mandatory
optional Status status = 6 [default = UP]; // Mandatory
optional IpAddress public_ip_address = 7;
optional IpAddress ip_address = 8;
optional string firmware_version = 9; // Mandatory
optional IpAddress default_gateway = 10;
optional uint32 device_mode = 11;
repeated string uplink_ports = 12;
optional uint32 max_slots = 13;
repeated string used_slots = 14;
repeated HardwareModule management_modules = 15;
repeated HardwareModule power_supplies = 16;
optional string stack_id = 17;
optional uint32 stack_member_id = 18;
optional StackMemberRole stack_member_role = 19;
optional MacAddress stack_macaddr = 20;
Parameters Descriptions
The following table lists the field, type, rule, and descriptions of the above mentioned protobuf messages
Field | Type | Rule | Description |
action | Action | Optional | Indicates the action. Contains any one of the following:
device_id | String | Optional | Indicates the associated device serial number. |
macaddr | MacAddress | Optional | Indicates the associated device Mac address.
status | Status | Optional | Indicates the device status as UP or Down. |
ipaddr | IpAddress | Optional | Indicates the IP address of the device. |
duplex_mode | Duplex | Optional | Indicates the duplex mode. Contains any one of the following:
name | String | Optional | Indicates the device name. |
port_number | String | Optional | Indicates the port number. |
type | IntfType | Optional | Indicates the interface type. Contains any of the following:
mode | String | Optional | Indicates the device mode. |
vlan | Uint32 | Optional | Indicates the assigned VLAN. |
has_poe | PoeSupport | Optional | Indicates the POE support. Contains any of the following:
poe_state | Status | Optional | Indicates the POE enabled device status, UP or DOWN. |
oper_state | Status | Optional | Indicates the operational status. |
admin_state | Status | Optional | Indicates the administrative state as UP or DOWN. |
speed | SpeedType | Optional | Indicates the speed information. Contains any of the following:
mux | Uint32 | Optional | Indicates the mux information. |
trusted | Uint32 | Optional | Indicates the trusted information. |
slot | String | Optional | Indicates the slot information. Usually it's name. |
phy_type | PortType | Optional | Indicates the port type. Contains any of the following:
sub_type | String | Optional | Indicates the sub type name. |
allowed_vlan | Uint32 | Repeated | Indicates the list of allowed VLANs. |
native_vlan | Uint32 | Optional | Indicates the native VLAN ID. |
vsx_enabled | Bool | Optional | Indicates the boolean value whether the vsx is enabled or not. |
state_down_reason | StateDownReason | Optional | Indicates the state down reason. Contains any one of the following:
vlan_mode | VlanModes | Optional | Indicates the VLAN mode. Contains any of the following:
timestamp | Uint32 | Optional | Indicates the timestamp when interface stats received. |
tx_bytes | Uint64 | Optional | Indicates the number of transmission bytes. |
rx_bytes | Uint64 | Optional | Indicates the number of received bytes. |
power_consumption | Uint32 | Optional | Indicates the power consumption of the device. |
in_errors | Uint64 | Optional | Indicates the number of input errors. |
out_errors | Uint64 | Optional | Indicates the number of output errors. |
in_discards | Uint64 | Optional | Indicates the number of input packet discards. |
out_discards | Uint64 | Optional | Indicates the number of output packet discards. |
in_packets | Uint64 | Optional | Indicates the number of input packets. |
out_packets | Uint64 | Optional | Indicates the number of output packets. |
in_other_err | Uint32 | Optional | Indicates the number of other errors. |
in_multicast_pkt | Uint64 | Optional | Indicates the number of multicast packets received in input. |
in_broadcast_pkt | Uint64 | Optional | Indicates the number of broadcast packets received in input. |
in_unicast_pkt | Uint64 | Optional | Indicates the number of unicast packets received in input. |
out_multicast_pkt | Uint64 | Optional | Indicates the number of multicast packets received in output. |
out_broadcast_pkt | Uint64 | Optional | Indicates the number of broadcast packets received in output. |
out_unicast_pkt | Uint64 | Optional | Indicates the number of unicast packets received in output. |
in_fcs | Uint64 | Optional | Indicates the number of input FCS. |
in_alignment | Uint64 | Optional | Indicates the number of input alignment. |
out_excessive_collision | Uint32 | Optional | Indicates the number of output excessive collision. |
in_jabbers | Uint64 | Optional | Indicates the number of input jabbers. |
in_fragmented | Uint64 | Optional | Indicates the number of inputs fragmented. |
in_giant | Uint32 | Optional | Indicates the number of input giant. |
in_runt | Uint32 | Optional | Indicates the number of input runt. |
out_collision | Uint64 | Optional | Indicates the number of collisions in outgoing packets. |
out_late_collision | Uint32 | Optional | Indicates the number of collision on an Ethernet network that is detected late in the transmission of the packet. |
out_deferred | Uint32 | Optional | Indicates the number of deferred outgoing packets. |
username | String | Optional | Indicates the client username. |
associated_device | String | Optional | Indicates the client connect device. |
interface_mac | MacAddress | Optional | Indicates the interface Mac address.
user_role | String | Optional | Indicates the user role. |
auth_type | AuthType | Optional | Indicates the client authentication method. |
rx_retries | Uint32 | Optional | Indicates the number of Rx retries. |
tx_retries | Uint32 | Optional | Indicates the number of Tx retries. |
speed | Uint32 | Optional | Shows the speed information. |
signal_in_db | Uint32 | Optional | Indicates the signal in decibels. |
snr | Uint32 | Optional | Indicates the signal noise ratio info. |
port | String | Optional | Indicates the port of the switch where the neighbor device is connected. |
remote_device_id | String | Optional | Indicates the remote device serial number. |
remote_port | String | Optional | Indicates the remote device connected port number. |
remote_port_number | String | Optional | Indicates the port number of the remote device. |
vlan_id | String | Optional | Indicates the client assigned VLAN. |
uptime | Uint64 | Optional | Indicates the switch uptime. |
cpu_utilization | Uint32 | Optional | Indicates the device CPU utilization. |
mem_total | Uint64 | Optional | Indicates the device total memory. |
mem_free | Uint64 | Optional | Indicates the device free memory available. |
fan_speed | Uint32 | Optional | Indicates the device fan speed. |
temperature | Uint32 | Optional | Indicates the device temperature value. |
fan_status | Status | Optional | Indicates the device fan status. |
max_power | Uint32 | Optional | Indicates max power of the device. |
poe_consumption | Uint32 | Optional | Indicates the device POE consumption. |
poe_budget | Uint32 | Optional | Indicates the device POE budget. |
mem_utilization | Uint64 | Optional | Indicates the device memory utilization. |
stack_id | String | Optional | Indicates the stack ID. |
topology | StackTopology | Optional | Indicates the stack topology. Contains any of the following:
policy | StackPolicy | Optional | Indicates the stack policy. Contains any of the following:
firmware_version | String | Optional | Indicates the version of the firmware. |
vsf_domain_id | Uint32 | Optional | Indicates the VSF domain ID. VSF uses VSF domain IDs to uniquely identify VSF fabrics and prevent VSF fabrics from interfering with one another. |
serial | String | Optional | Indicates the device serial number. |
model | String | Optional | Indicates the device model. |
public_ip_address | IpAddress | Optional | Indicates the public IP address of the switch.
ip_address | IpAddress | Optional | Indicates the IP address of the switch.
default_gateway | IpAddress | Optional | Indicates the default gateway on switch. Contains the following:
device_mode | Uint32 | Optional | Indicates the device mode on switch. |
uplink_ports | String | Optional | Indicates the uplink ports on switch. |
max_slots | Uint32 | Optional | Indicates the maximum number of slots on a switch. |
used_slots | String | Repeated | Indicates the number of used slots on a switch. |
management_modules | HardwareModule | Repeated | Indicates the number of management modules. |
power_supplies | HardwareModule | Repeated | Indicates the power supplies or the number of power supplies. |
stack_member_id | Uint32 | Optional | Indicates the unique identifier of the stack member. |
stack_member_role | StackMemberRole | Optional | Indicates the stack member role. Contains any of the following:
stack_macaddr | MacAddress | Optional | Indicates the mac address of a stack switch.
Examples for AOS Switch Streaming Events within Monitoring Topic
interfaces
action: DELETE
device_id: "CG0020759"
macaddr {
addr: " L\003\006qo"
status: DOWN
duplex_mode: AUTO
port_number: "14"
type: ETHERNET
mode: "Access"
vlan: 13
oper_state: DOWN
admin_state: DOWN
speed: SPEED_1000
slot: "0"
sub_type: "2"
interfaces_stats
device_id: "TWJCKSP01C"
macaddr {
addr: " L\003\225\352v"
timestamp: 1603163100
tx_bytes: 3155
rx_bytes: 2002
in_packets: 25
out_packets: 49
in_other_err: 0
in_multicast_pkt: 24
in_broadcast_pkt: 0
in_unicast_pkt: 1
out_multicast_pkt: 0
out_broadcast_pkt: 3
out_unicast_pkt: 46
device_neighbours
action: UPDATE
device_id: "DZ0001581"
port: 3
remote_device_id: "DZ0001581"
remote_port: 4
remote_port_number: 2
vlan_id: 1
device_stats
timestamp: 1601898300
uptime: 364223
cpu_utilization: 7
mem_total: 490090496
mem_free: 234157664
mem_utilization: 52
switch_stack
action: UPDATE
stack_id: "1234122"
status: UP
topology: CHAIN
policy: STACK_SPLIT_ALL_FRAGMENTS_UP
firmware_version: "8.0.1.0-sp_73970"
vsf_domain_id: 100
Updated about 2 years ago
