Access Point Alerts
Following are the Access Point alerts that you can configure for notification over Webhooks. Click on an alert to see its description and JSON payload:
- New Virtual Controller Detected
- Virtual Controller Disconnected
- New AP Detected
- AP Disconnected
- Rogue AP Detected
- Infrastructure Attack Detected
- Client Attack Detected
- Uplink Changed
- Modem Unplugged
- Modem Plugged
- AP CPU Utilization
- AP Memory Utilization
- Insufficient Power Supplied
- Radio Channel Utilization
- Radio Noise Floor
- Connected Clients per VC
- Connected Clients per IAP
- Radio Frames Retry Percent
- AP Tunnel Down
- IAP Firmware Upgrade Failed
- Radio Non Wifi Utilization
Generates an alert when a new virtual controller is detected.
"id": "AXasdghjwq123wiJ43hVq",
"nid": 1,
"alert_type": "New Virtual Controller detected",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1",
"device_id": "",
"description": "New Virtual controller SetMeUp-CC:FF:6A with version 8.7.1.0_77203
and IP address 10.10.10.10 detected, Group:unprovisioned",
"state": "Open",
"severity": "Major",
"operation": "create",
"timestamp": 1612247504,
"details": {
"group": "1",
"labels": "",
"_rule_number": "0",
"params": [
"SetMeUp-CC:FF:6A",
"8.7.1.0_77203",
"10.10.10.10",
"DZ0001581"
"serial": "None",
"time": "2021-02-02 06:31:44 UTC",
"group_name": "unprovisioned"
"webhook": "14aasddb-0ee1-23ew-76yg-lkj50xxzzba",
"text": "New Virtual controller SetMeUp-CC:FF:6A with version 8.7.1.0_77203
}Virtual Controller Disconnected
Generates an alert when a virtual controller is disconnected. This alert is enabled by default and the alert severity is automatically set to Major. To customize the alert trigger, enter a duration in minutes, in the Duration field. By default, the trigger to generate the alert is set to 10 minutes.
"nid": 2,
"alert_type": "Virtual controller disconnected",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-2",
"device_id": "DZ0001581",
"description": "Virtual controller SetMeUp-C9:F7:6A with version 8.7.1.0_77203 and
IP address 10.29.6.170 disconnected, Group:unprovisioned",
"state": "Open",
"timestamp": 1612248179,
"details": {
"params": [
"DZ0001581",
"f0:5c:19:c9:f7:6a",
"10.29.6.170",
"SetMeUp-C9:F7:6A",
"8.7.1.0_77203",
"group": "1",
"ts": "1612247876960",
"labels": "",
"serial": "DZ0001581",
"conn_status": "disconnected",
"time": "2021-02-02 06:42:59 UTC",
"text": "Virtual controller SetMeUp-C9:F7:6A with version 8.7.1.0_77203 and
}New AP Detected
Generates an alert when a new Instant AP is detected.
"nid": 3,
"alert_type": "New AP detected",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-3",
"description": "New AP f0:5c:19:c9:f7:6a with MAC address f0:5c:19:c9:f7:6a detected, Group:unprovisioned",
"state": "Open",
"timestamp": 1612247560,
"details": {
"group": "1",
"labels": "",
"params": [
"f0:5c:19:c9:f7:6a"
"time": "2021-02-02 06:32:40 UTC",
"text": "New AP f0:5c:19:c9:f7:6a with MAC address f0:5c:19:c9:f7:6a detected, Group:unprovisioned"
}AP Disconnected
Generates an alert when an Instant AP is disconnected. This alert is enabled by default and the alert severity is automatically set to Major. To customize the alert trigger, enter a duration in minutes, in the Duration field. By default, the trigger to generate the alert is set to 15 minutes.
"nid": 4,
"alert_type": "AP disconnected",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-4",
"description": "AP f0:5c:19:c9:f7:6a with MAC address f0:5c:19:c9:f7:6a disconnected,
"state": "Open",
"timestamp": 1612247279,
"details": {
"params": [
"DZ0001581",
"10.29.6.170",
"group": "1",
"ts": "1612246960735",
"labels": "",
"time": "2021-02-02 06:27:59 UTC",
"text": "AP f0:5c:19:c9:f7:6a with MAC address f0:5c:19:c9:f7:6a disconnected,
}Rogue AP Detected
Generates an alert when a rogue IAP is detected. This alert is enabled by default and the alert severity is Major.
"alert_type": "Rogue AP detected",
"description": "An AP (NAME 84:d4:7e:c5:c8:8c and MAC address 84:d4:7e:c5:c8:8con RADIO 1)
detected an access point
(BSSID 0c:00:01:34:69:62 and SSID ssid1 on CHANNEL 52) as rogue",
"timestamp": 1564326128,
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-10",
"state": "Open",
"nid": 10,
"details": {
"group": "1",
"labels": "",
"params": [
"84:d4:7e:c5:c8:8c",
"1",
"0c:00:01:34:69:62",
"ssid1",
"52"
"time": "2019-07-28 15:02:08 UTC"
"device_id": "CT0779239",
"severity": "Critical"
}Infrastructure Attack Detected
Generates an alert when an infrastructure attack is detected.
"alert_type": "Infrastructure attack detected",
"description": "An AP (NAME iap-303-iphone456-o and MAC 90:4c:81:cf:27:74 on RADIO 1) detected that the Access Point with
MAC f0:5c:19:23:56:10 and BSSID f0:5c:19:23:56:10 has sent a beacon for SSID tan This beacon advertizes channel 149
but was received on channel 161 with SNR 50 ",
"timestamp": 1564400165,
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-12",
"state": "Open",
"nid": 12,
"details": {
"group": "3",
"labels": "3,142,141",
"params": "None",
"time": "2019-07-29 11:36:05 UTC"
"device_id": "CNGHKGX004",
}Client Attack Detected
Generates an alert when a client attack is detected.
"alert_type": "Client attack detected",
"description": "An AP (NAME iap-303-iphone456-o and MAC 90:4c:81:cf:27:74 on RADIO 1) detected an unencrypted frame
between a valid client (88:63:df:bb:2a:9d) and access point (BSSID 90:4c:81:72:77:55) with source 88:63:df:bb:2a:9d
and receiver ff:ff:ff:ff:ff:ff SNR value is 55",
"timestamp": 1564392710,
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-13",
"state": "Open",
"nid": 13,
"details": {
"group": "3",
"params": "None",
"time": "2019-07-29 09:31:50 UTC"
}Uplink Changed
Generates an alert when an uplink has changed.
"nid": 17,
"alert_type": "Uplink Changed",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-17",
"device_id": "GRUT000003",
"description": "Uplink changed from Ethernet to WiFi Mesh for AP GRUT000003 with MAC address 3d:62:d4:3f:90:00",
"state": "Open",
"timestamp": 1612250162,
"details": {
"group": "0",
"labels": "",
"params": [
"Ethernet",
"WiFi Mesh",
"GRUT000003",
"3d:62:d4:3f:90:00"
"serial": "GRUT000003",
"time": "2021-02-02 07:16:02 UTC"
"text": "Uplink changed from Ethernet to WiFi Mesh for AP GRUT000003 with MAC address 3d:62:d4:3f:90:00"
}Modem Unplugged
Generates an alert when the modem is unplugged.
"nid": 19,
"alert_type": "Modem Unplugged",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-19",
"device_id": "GRUT000001",
"description": "Modem unplugged from AP GRUT000001 with MAC address 64:2a:90:97:f0:00",
"state": "Open",
"timestamp": 1612251096,
"details": {
"group": "0",
"labels": "",
"params": [
"GRUT000001",
"64:2a:90:97:f0:00"
"serial": "GRUT000001",
"time": "2021-02-02 07:31:36 UTC"
"text": "Modem unplugged from AP GRUT000001 with MAC address 64:2a:90:97:f0:00"
}Modem Plugged
Generates an alert when the modem is plugged.
"nid": 18,
"alert_type": "Modem Plugged",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-18",
"device_id": "GRUT000002",
"description": "Modem plugged to AP GRUT000002 with MAC address 4a:36:66:b8:50:00",
"state": "Open",
"timestamp": 1612250188,
"details": {
"group": "0",
"labels": "",
"params": [
"GRUT000002",
"4a:36:66:b8:50:00"
"serial": "GRUT000002",
"time": "2021-02-02 07:16:28 UTC"
"text": "Modem plugged to AP GRUT000002 with MAC address 4a:36:66:b8:50:00"
}AP CPU Utilization
Generates an alert when the Instant AP CPU utilization exceeds the threshold value. In the Duration field, enter the duration after which the alert must be generated. You can add additional rule(s) for this alert.
"nid": 1250,
"alert_type": "AP_CPU_OVER_UTILIZATION",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1250",
"device_id": "CNDSHN74L6",
"description": "CPU utilization for AP 20:a6:cd:cc:17:58 with serial CNDSHN74L6 has been
above 1% for about 5 minutes since 2021-02-02 06:11:00 UTC",
"state": "Open",
"severity": "Critical",
"timestamp": 1612246560,
"details": {
"name": "20:a6:cd:cc:17:58",
"unit": "%",
"serial": "CNDSHN74L6",
"group": "1",
"labels": "3",
"ds_key": "55ef4ae129a24c2180e010708202b502.CNDSHN74L6.cpu_utilization.5m",
"duration": "5",
"threshold": "1",
"time": "2021-02-02 06:11:00 UTC"
"text": "CPU utilization for AP 20:a6:cd:cc:17:58 with serial CNDSHN74L6 has been
}AP Memory Utilization
Generates an alert when the Instant AP memory utilization exceeds the threshold value. In the Duration field, enter the duration after which the alert must be generated. You can add additional rule(s) for this alert.
"nid": 1251,
"alert_type": "AP_MEMORY_OVER_UTILIZATION",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1251",
"description": "Memory utilization for AP 20:a6:cd:cc:17:58 with serial CNDSHN74L6 has been
above 10% for about 5 minutes since 2021-02-02 06:11:00 UTC",
"state": "Open",
"details": {
"unit": "%",
"group": "1",
"labels": "3",
"ds_key": "55ef4ae129a24c2180e010708202b502.CNDSHN74L6.memory_utilization.5m",
"duration": "5",
"threshold": "10",
"text": "Memory utilization for AP 20:a6:cd:cc:17:58 with serial CNDSHN74L6 has been
}Insufficient Power Supplied
Generates an alert when the IAP is supplied with lesser power than the required power.
"nid": 21,
"alert_type": "INSUFFICIENT_POWER_ALERT",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-21",
"description": "Insufficient inline power supplied to AP-325 with name 20:a6:cd:cc:17:58",
"state": "Open",
"timestamp": 1612247105,
"details": {
"ap_model": "AP-325",
"group": "1",
"labels": [
"3"
"rule_number": "0",
"time": "2021-02-02 06:25:05 UTC"
"text": "Insufficient inline power supplied to AP-325 with name 20:a6:cd:cc:17:58"
}Radio Channel Utilization
Generates an alert when the Instant AP radio channel utilization exceeds the threshold value. In the Duration field, enter the duration after which the alert must be generated. From the Band drop-down, select the spectrum band: 2.4 GHz or 5 GHz. You can add additional rule(s) for this alert.
"nid": 1252,
"alert_type": "AP_RADIO_OVER_UTILIZATION",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1252",
"description": "Radio utilization on AP f0:5c:19:c9:f7:6a operating on channel 132E and
serving 0 clients has been above 5% for about 5 minutes since 2021-02-02 06:09:00 UTC",
"state": "Open",
"timestamp": 1612246440,
"details": {
"name": "f0:5c:19:c9:f7:6a",
"_band": "1",
"_radio_num": "0",
"channel": "132E",
"client_count": "0",
"unit": "%",
"group": "1",
"ds_key": "55ef4ae129a24c2180e010708202b502.DZ0001581.radio.busy64",
"duration": "5",
"threshold": "5",
"time": "2021-02-02 06:09:00 UTC"
}Radio Noise Floor
Generates an alert when the Noise Floor (dBm) exceeds the threshold value. In the Duration field, enter the duration after which the alert must be generated. From the Band drop-down, select the spectrum band: 2.4 GHz or 5 GHz. You can add additional rule(s) for this alert.
"nid": 1253,
"alert_type": "AP_RADIO_NOISE_FLOOR",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1253",
"description": "Noise floor on AP f0:5c:19:c9:f7:6a operating on channel 132E and
serving 0 clients has been above -100 dBm for about 5 minutes since 2021-02-02 06:09:00 UTC",
"state": "Open",
"details": {
"_band": "1",
"_radio_num": "0",
"channel": "132E",
"unit": "%",
"group": "1",
"ds_key": "55ef4ae129a24c2180e010708202b502.DZ0001581.radio.noisefloor",
"duration": "5",
"threshold": "100",
"text": "Noise floor on AP f0:5c:19:c9:f7:6a operating on channel 132E and serving
}Connected Clients per VC
Generates an alert when the number of connected clients to the VC exceeds the threshold value. In the Duration field, enter the duration after which the alert must be generated. You can add additional rule(s) for this alert.
"nid": 1254,
"alert_type": "CONNECTED_CLIENTS",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1254",
"device_id": "cf62d07c019cd6bca90e6079e351251070d9e286f310c87541",
"description": "Number of clients connected to VC SetMeUp-C9:F7:6A has been
above 1 for about 5 minutes since 2021-02-02 06:01:00 UTC",
"state": "Open",
"timestamp": 1612245960,
"details": {
"customer_id": "55ef4ae129a24c2180e010708202b502",
"name": "SetMeUp-C9:F7:6A",
"serial": "cf62d07c019cd6bca90e6079e351251070d9e286f310c87541",
"group": "1",
"ds_key": "55ef4ae129a24c2180e010708202b502.cluster.363.device.clients.5m",
"duration": "5",
"threshold": "1",
"time": "2021-02-02 06:01:00 UTC"
"text": "Number of clients connected to VC SetMeUp-C9:F7:6A has been above 1 for
}Connected Clients per IAP
Generates an alert when the number of connected clients to the AP exceeds the threshold value. You can enter the threshold value after which the alerts must be generated. The recommended value is 15 minutes and above. You can add additional rule(s) for this alert.
"nid": 1255,
"alert_type": "AP_CONNECTED_CLIENTS",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1255",
"description": "Number of clients connected to AP 20:a6:cd:cc:17:58 has been
above 1 for about 5 minutes since 2021-02-02 06:11:00 UTC",
"state": "Open",
"details": {
"group": "1",
"labels": "3",
"ds_key": "55ef4ae129a24c2180e010708202b502.CNDSHN74L6.device.clients.5m",
"duration": "5",
"threshold": "1",
"text": "Number of clients connected to AP 20:a6:cd:cc:17:58 has been
}Radio Frames Retry Percent
Generates an alert when the Instant AP radio frames retry percent exceeds the threshold value. In the Duration field, enter the duration after which the alert must be generated. From the Band drop-down, select the spectrum band: 2.4 GHz or 5 GHz. You can add additional rule(s) for this alert.
"nid": 1256,
"alert_type": "AP_TX_RETRY_PERCENT",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1256",
"device_id": "VEYB000004",
"description": "Radio frames retry percent for AP VEYB000004 with serial VEYB000004 has been
above 1% for about 5 minutes since 2021-02-04 05:06:00 UTC",
"state": "Open",
"timestamp": 1612415460,
"details": {
"name": "VEYB000004",
"_band": "0",
"_radio_num": "0",
"channel": "11",
"client_count": "1",
"unit": "%",
"serial": "VEYB000004",
"group": "2",
"labels": "4",
"ds_key": "2a35217e2f114cd8958f00a676258785.VEYB000004.radio.retry_percent",
"duration": "5",
"threshold": "1",
"time": "2021-02-04 05:06:00 UTC"
"text": "Radio frames retry percent for AP VEYB000004 with serial VEYB000004 has been
}AP Tunnel Down
Generates an alert when a single L3 tunnel configured on the AP goes down.
"nid": 1257,
"alert_type": "AP_TUNNEL_DOWN",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1257",
"description": "AP tunnel vpn_tun_default_0 from 0.0.0.0 to 0.0.0.0 is DOWN on
device 20:a6:cd:cc:17:58 with serial CNDSHN74L6 at 2021-02-02 06:44:25 UTC.",
"state": "Open",
"timestamp": 1612248265,
"details": {
"src_ip": "0.0.0.0",
"dst_ip": "0.0.0.0",
"alias_map_name": "vpn_tun_default_0",
"group": "86",
"labels": "3",
"rule_number": "0",
"time": "2021-02-02 06:44:25 UTC"
"text": "AP tunnel vpn_tun_default_0 from 0.0.0.0 to 0.0.0.0 is DOWN on
}IAP Firmware Upgrade Failed
Generates an alert when there is any Instant AP upgrade failure such as, no firmware image is available or there is no response from the device.
"nid": 2200,
"alert_type": "IAP_FW_UPGRADE_FAILURE",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-2200",
"device_id": "",
"description": "Firmware upgrade failed for AP CNDSHN74L6 with serial None and
MAC address 20:a6:cd:cc:17:58",
"state": "Open",
"timestamp": 1612248004,
"details": {
"mac": "20:a6:cd:cc:17:58",
"hostname": "CNDSHN74L6",
"serial": "None",
"group": "86",
"labels": "",
"params": "None",
"time": "2021-02-02 06:40:04 UTC"
"text": "Firmware upgrade failed for AP CNDSHN74L6 with serial None and
}Radio Non Wifi Utilization
Generates an alert when the IAP radio non-Wi-Fi utilization exceeds the threshold value. In the Duration field, enter the duration after which the alert must be generated. From the Band drop-down, select the spectrum band: 2.4 GHz or 5 GHz. You can add additional rule(s) for this alert.
"nid": 1259,
"alert_type": "AP_RADIO_NON_WIFI_OVER_UTILIZATION",
"setting_id": "e1234567xxxyyyzbcccddddfff8140d8-1259",
"description": "Radio Non-Wifi utilization on AP f0:5c:19:c9:f7:6a operating on channel 6
and serving 0 clients has been above 1% for about 5 minutes since 2021-02-02 06:09:00 UTC",
"state": "Open",
"details": {
"_band": "0",
"_radio_num": "1",
"channel": "6",
"unit": "%",
"group": "1",
"ds_key": "55ef4ae129a24c2180e010708202b502.DZ0001581.radio.interference",
"duration": "5",
"threshold": "1",
"text": "Radio Non-Wifi utilization on AP f0:5c:19:c9:f7:6a operating on channel 6
}Updated 3 months ago
