Device Provisioning
PyCentral Workflow
This workflow allows users to provision & deploy device(s) in Classic Central using a Python script that utilizes the PyCentral library. Once devices are assigned Classic Central subscriptions, they need to be deployed to a location. This script automates that workflow.
Workflow Overview
Device Provisioning Flowchart
Group Creation
The script creates a group on Classic Central. A group is the primary configuration element that functions as a container for device management, monitoring, and maintenance. The group that the script creates is a CLI-based configuration template group
Upload Configuration to group
After the group is created it has to be provided with configuration. The script uploads template files that hold CLI-based configuration. The script allows each device type(for eg. AP, AOS-CX Switch, etc.) to have one configuration file.
Move Device(s) to group
After the group is configured, devices can be moved into it. These devices will get the configuration as defined in the group.
Create a Site
While groups handle configuration, a site in Classic Central refers to a physical location where a set of devices are installed. The script creates a site to indicate where the devices will be located.
Associate Device(s) to Site
After the site is created, the script then associates the devices to the site. This indicates to Classic Central that the physical location of the devices.
Script's Input Files
As a user, you only need to input details in the following files before running the script
central_token.json-> This file has the Classic Central API Gateway Base URL & Access Token. These details are needed for the script to connect with Central via REST APIs. Here is a sample file - central_token.jsonworkflow_variables.json-> This file has the following details relevant to the workflow-- Group - Details of the group like name, attributes, & configuration file paths.
- Site - Details of the site like name & address
- Device - Serial number of device(s)
Sample Files
You can check out the sample files here - central_token.json & workflow_variables.json
You can find the complete script & installation instructions for this workflow here.
Please check out other Classic Central workflows utilizing PyCentral in central-python-workflows GitHub repository.
Updated 5 days ago
