HomeGuidesAPI Reference
GuidesAPI ReferenceGitHubAirheads Developer CommunityLog In
PyCentral Features
As part of the PyCentral v1 release, some new features have been added to simplify and enhance your automation experience.
Authentication Options
PyCentral offers three distinct ways of handling authentication data, each tailed to different security requirements & user scenarious. Authentication details that's required for PyCentral to make API calls to Classic Central can be provided either in a JSON file or directly within the script. Each method caters to different security and workflow requirements
BaseURL & Access Token
        "base_url": "",
        "token": {
            "access_token": ""
VariableDescription
base_urlDomain Base URL for Classic Central API Gateway is based on the geographical cluster where your Classic Central account is registered. You can find the list of Base URLs here or in the Overview section of the Classic Central Postman Collection.
access_tokenAccess Token is required to securely make an API Request to Classic Central API Gateway.
VariableDescription
base_urlDomain Base URL for Classic Central API Gateway based on the geographical cluster where your account is registered.
client_idUnique Application ID associated with the client.
client_secretUnique Application secret ID associated with the client.
refresh_tokenRefresh tokens are used to refresh the access_token when it expires without having to repeat the above API calls.
Per Second Rate Limit
Whenever the per-second API rate limit is reached for the Classic Central account, PyCentral pauses script execution for 2 seconds for the rate limit to be reset before continuing execution. It will also log the following message to the terminal to indicate the same to the user
Per-second rate limit reached. Adding 2 seconds interval and retrying.
Per Day Rate Limit
When the per-day API rate limit is exhausted for the Classic Central account, PyCentral will log a message indicating that and exit from executing the script.
"Per-day rate limit of 5000 is exhausted. Please check Classic Central UI to see when the daily rate limit quota will be reset
