Aruba's SSH modules for AOS 8 based devices are packaged along side modules for some other products like Airwave, Activate, ClearPass, etc. in this repository on Github.
The aruba_module_installer.py tool located under aruba_module_installer folder, installs all files/directories required by Ansible for WLAN module integration.
Two modules are available as SSH modules:
- aruba_config: For passing CLI configuration commands using a playbook
- aruba_command: For passing all the non-configuration commands (where config prompt is not needed) using a playbook
Requirements
- Linux operating system
- Python 2.7 or 3.5+
- Ansible version 2.5 or later
How to run this code
From command line:
$ python aruba_module_installer.py
If you receive a permission error, use 'sudo':
$ sudo python aruba_module_installer.py
In order to run these scripts, please complete the steps below:
- Install Python version 2.7 or 3.5+ on the system.
- Install Ansible 2.5 or later
Note
The module installer script will install modules into Ansible default module folder
How to install updates or new modules
Enter the cloned directory and pull any updates from the repository:
$ cd aruba-ansible-modules
$ git pull
Run the python installer with the --reinstall
option, remember to use sudo
if you receive a permission error:
$ sudo python aruba_module_installer/aruba_module_installer.py --reinstall
optional arguments:
-h, --help show this help message and exit
-r, --remove remove all files & directories installed by this script.
--reinstall remove all files & directories installed by this script. Then
re-install.
--switch only install files/directories required for AOS-Switch.
The variables that should be defined in your inventory/host file for your AOS 8 host are:
ansible_host
: IP address of mobility conductor/standalone inA.B.C.D
formatansible_user
: Username for mobility conductor/standalone inplaintext
formatansible_password
: Password for mobility conductor/standalone inplaintext
formatansible_connection
: Must always be set tolocal
ansible_network_os
: Must always be set toaruba
Sample Inventories:
Sample inventory.yml
all
hosts
controller
ansible_host10.1.1.1
ansible_user admin
ansible_password[email protected]
ansible_connection local
ansible_network_os aruba
aruba_1 ansible_host=10.1.1.1 ansible_user=admin [email protected] ansible_connection=local ansible_network_os=aruba
Example Playbook
name configure top level configuration
aruba_config
lines hostname inventory_hostname
Updated 3 months ago
