HMAC Authentication
Data integrity checks are vital to secure a communication. HPE Aruba Networking Central Webhooks provides a way to validate the authenticity and integrity of the alert events data received by the user application using HMAC. Hash-based Message Authentication Code (HMAC) is a mechanism for calculating a message authentication code involving a hash function in combination with a secret key.
HMAC Algorithm
In order to use the HMAC, a message digest is computed first. Message digest is a fixed size numeric representation of the contents of a message, computed by a hash function. The following are required to compute message digest.
- Secret Key / Token of HPE Aruba Networking Central Webhook
- HTTP data to be authenticated (received from HPE Aruba Networking Central Webhook)
- headers [
X-Central-Service,X-Central-Delivery-IDandX-Central-Delivery-Timestamp]
To validate the integrity of the received message, the computed authentication code should be same as the received HTTP message header[X-Central-Signature]. When an attacker tampers the message in between HPE Aruba Networking Central and end user application, the resulting hash will not match the header[X-Central-Signature].
To validate authenticity (i.e., if the data is sent by legit source such as HPE Aruba Networking Central), HMAC makes use of the shared secret key / token to compute the authentication code. Thus checking if the computed signature with the header[X-Central-Signature] validates both integrity and authenticity of the received Webhook message.
Obtaining Secret Key / Token
A secret key or token will be generated in HPE Aruba Networking Central upon creation of Webhooks. To obtain the secret key for a webhook,
Web UI
- Follow Account Home -> Global Settings -> Webhooks to get to the Webhook table.
- The webhook table contains the following columns: Name, Number of URL Entries, Updated At, Webhook ID, Token, Edit, Delete
- Copy the Token field from the required Webhook entry.
REST API
To obtain security key/token via REST API pick one of the options below.
- Get Webhook ID from list of Webhooks
List of all Webhooks are returned with this API call. The Webhook ID and the security key / token can be obtained from the list.
API Endpoint:/central/v1/webhooks
API Method: GET
Base URL:https://apigw-prod2.central.arubanetworks.com/(Replace the Base URL with correct API Gateway)
Request Header:'Content-Type': 'application/json'; 'Authorization': 'Bearer <access-token>'{ "count": 1, "settings": [ { "wid": "e26450be-4dac-435b-ac01-15d8f9667eb8", "name": "AAA", "updated_ts": 1523956927, "urls": [ "https://example.org/webhook1", "https://example.org/webhook1" ], "secure_token": { "token": "KEu5ZPTi44UO4MnMiOqz", "ts": 1573461177 } } ] } - Find from specific Webhook ID
You can get details of a specific webhook with this API. Security token will be available in the response JSON message of that API.
API Endpoint:/central/v1/webhooks/{wid}
API Method: GET
Request Header:'Content-Type': 'application/json'; 'Authorization': 'Bearer <access-token>'{ "wid": "e26450be-4dac-435b-ac01-15d8f9667eb8", "name": "AAA", "updated_ts": 1523956927, "urls": [ "https://example.org/webhook1", "https://example.org/webhook1" ], "secure_token": { "token": "KEu5ZPTi44UO4MnMiOqz", "ts": 1573461177 } } - Get Webhook Token
You can get just the security token of the webhook(based on the webhook ID) with this API.
API Endpoint:/central/v1/webhooks/{wid}/token
API Method: GET
Request Header:'Content-Type': 'application/json'; 'Authorization': 'Bearer <access-token>' \{ "name": "AAA", "secure_token": "[{\"token\": \"zSMrzuYrblgBfByy2JrM\", \"ts\": 1523957233}]" }
Refreshing Webhook Secret Key / Token
There might be a need for the end user application to refresh the secret key / token of a Webhook for additional security. A REST API call can be made periodically to refresh the Webhook secret key based on the user's requirement.
API Endpoint: /central/v1/webhooks/{wid}/token
API Method: PUT
Base URL: https://apigw-prod2.central.arubanetworks.com/ (Replace the Base URL with correct API Gateway)
Request Header: 'Content-Type': 'application/json'; 'Authorization': 'Bearer <access-token>'
"name": "AAA",
You can also find this API in our API Reference Guide here.
Updated 5 months ago
