Assign Sensor to a New Group
An example of how to create a new group, assign a sensor to the group and ensure that the sensor is testing a network.
The User Experience Insight (UXI) Onboarding API allows you to simplify most of the tasks associated with assigning your sensors and agents to the proper groups and configuring them to test your networks and services. To use the API, your dashboard must be on the Greenlake Cloud Platform. Additionally, you must be using the group-based assignment feature.
You can find documentation for the Onboarding API here:
Download the OpenApi specification.
Prerequisites
You will need to create a personal API client for the User Experience Insight service manager on the Greenlake Cloud Platform. See the detailed instructions on creating your personal API client in the Greenlake developer guide.
Example Scenario
In this example, suppose we want to create a group and assign a sensor to the newly created group. Additionally we want to make sure that the sensor will run tests against at least one network.
Endpoints
Here are the endpoints you will need:
- /networking-uxi/v1alpha1/groups
- /networking-uxi/v1alpha1/wireless-networks
- /networking-uxi/v1alpha1/network-group-assignments
- /networking-uxi/v1alpha1/sensor-group-assignments
Note: The API uses cursor-based pagination.
Putting it together
Here is a Python 3 example of this in action. This example uses Python requests to create a new group and assign a sensor to the group. If the new group does not inherit any network assignments, a wireless network is assigned to the group as well.
This example does the following:
- Generates a temporary access token using the credentials of the personal API client
- Creates a new group as a child of a known parent
- Assigns a sensor to the group
- Checks whether any networks are assigned to the group or any parent of the group (child groups inherit network assignments from their parents).
- If no networks have been assigned to the group or any parent, then a wireless network is assigned to the group.
WARNING: This example is for demonstration purposes only. This example lacks robust error handling and optimizations necessary for a production environment. Do not use the example code in a production environment.
from typing import Any
import requests
from oauthlib.oauth2 import BackendApplicationClient
from requests.auth import HTTPBasicAuth
from requests_oauthlib import OAuth2Session
# Global constants
AUTH_TOKEN_URL = "<https://sso.common.cloud.hpe.com/as/token.oauth2">
UXI_API_BASE_URL = "<https://api.capenetworks.com/networking-uxi/v1alpha1">
# Customer specific constants
CLIENT_ID = "\<CLIENT_ID>"
CLIENT_SECRET = "\<CLIENT_SECRET>"
# Example specific constants
# The ID of the parent group to use when creating the new group. The new group will be created as a child of this group.
# This can be retrieved from the API: /networking-uxi/v1alpha1/groups.
PARENT_GROUP_ID = "\<PARENT_GROUP_ID>" # eg: 9bfded8bd7cb
# The ID of the sensor to assign to the new group.
# This can be retrieved from the API: /networking-uxi/v1alpha1/sensors.
SENSOR_ID = "\<SENSOR_ID>" # eg: 9108f997-32a0-45ca-ab00-c8c93273c332
def main():
api_token = get_api_token()
child_group_id = create_group(
api_token=api_token,
group_name="Child Group",
parent_id=PARENT_GROUP_ID,
if not child_group_id:
exit(1)
all_groups = get_groups(api_token=api_token)
# Ensure that at least 1 network is assigned to the new group.
networks_assigned_to_group = get_networks_assigned_to_group(
api_token=api_token, all_groups=all_groups, group_id=child_group_id
if not networks_assigned_to_group:
wireless_networks = get_wireless_networks(api_token=api_token)
if not wireless_networks:
return
# assign a wireless network to the new group
assign_network_to_group(
group_id=child_group_id,
network_id=wireless_networks[0]["id"],
assign_sensor_to_group(
api_token=api_token, sensor_id=SENSOR_ID, group_id=child_group_id
def get_api_token() -> str:
client = BackendApplicationClient(CLIENT_ID)
oauth = OAuth2Session(client=client)
auth = HTTPBasicAuth(CLIENT_ID, CLIENT_SECRET)
token = oauth.fetch_token(token_url=AUTH_TOKEN_URL, auth=auth)
return token["access_token"]
def create_group(
api_token: str, group_name: str, parent_id: str
) -> str | None:
HEADERS = {
"Authorization": f"Bearer {api_token}",
"Content-Type": "application/json",
request_body = {"name": group_name, "parentId": parent_id}
try:
response = requests.post(f"{UXI_API_BASE_URL}/groups", headers=HEADERS, json=request_body)
response.raise_for_status()
response_body = response.json()
print(f"Successfully created group: {response_body['name']}")
return response_body["id"]
except requests.exceptions.HTTPError as e:
print(f"Failed to create group: {e.response.text}")
def assign_network_to_group(
api_token: str, group_id: str, network_id: str
) -> str | None:
HEADERS = {
request_body = {"groupId": group_id, "networkId": network_id}
try:
f"{UXI_API_BASE_URL}/network-group-assignments", headers=HEADERS, json=request_body
print(f"Successfully assigned network '{network_id}' to group '{group_id}'")
print(f"Failed to assign network '{network_id}' to group '{group_id}': {e.response.text}")
def assign_sensor_to_group(api_token: str, sensor_id: str, group_id: str) -> str | None:
HEADERS = {
payload = {"sensorId": sensor_id, "groupId": group_id}
try:
f"{UXI_API_BASE_URL}/sensor-group-assignments",
headers=HEADERS,
json=payload,
print(f"Successfully assigned sensor '{sensor_id}' to group '{group_id}'.")
print(f"Failed to assign sensor '{sensor_id}' to group '{group_id}': {e.response.text}")
def get_networks_assigned_to_group(
api_token: str, all_groups: list\[dict[str, Any]], group_id: str
) -> list\[dict[str, Any]]:
# Groups inherit the network assignments from their parents.
# To know which networks are assigned to a particular group, we need to know
# which networks are directly assigned to the group itself as well as any of the
# groups parents.
group_parents = get_group_parents(all_groups=all_groups, group_id=group_id)
network_group_assignments = get_network_group_assignments(api_token=api_token)
group_lineage = [parent["id"] for parent in group_parents] + [group_id]
return [
assignment
for assignment in network_group_assignments
if assignment["group"]["id"] in group_lineage
def get_group_parents(all_groups: list\[dict[str, Any]], group_id: str) -> list\[dict[str, Any]]:
group_map = {group["id"]\: group for group in all_groups}
def _get_parent(group_id: str) -> list[dict[str, Any]]:
group = group_map.get(group_id)
if not group or not group.get("parent", None):
return []
parent_id = group["parent"]["id"]
return _get_parent(parent_id) + [group_map[parent_id]]
return _get_parent(group_id)
def get_groups(api_token: str) -> list\[dict[str, Any]]:
return \_get_items(path="groups", api_token=api_token)
def get_network_group_assignments(api_token: str) -> list\[dict[str, Any]]:
return \_get_items(path="network-group-assignments", api_token=api_token)
def get_wireless_networks(api_token: str) -> list\[dict[str, Any]]:
return \_get_items(path="wireless-networks", api_token=api_token)
def \_get_items(path: str, api_token: str) -> list\[dict[str, Any]]:
HEADERS = {
items: list\[dict[str, Any]] = \[]
next_cursor = None
# This while loop exists to keep making requests until all data for the specified resource is fetched.
while True:
try:
params = {"next": next_cursor} if next_cursor else {}
response = requests.get(
f"{UXI_API_BASE_URL}/{path}", headers=HEADERS, params=params
response_body: dict[str, Any] = response.json()
response_items: list[dict[str, Any]] = response_body.get("items", [])
next_cursor = response_body.get("next")
items.extend(response_items)
if not next_cursor or not response_items:
break
print(f"Error fetching items ({path}): {e}")
break
return items
if **name** == "**main**":
main()
Updated about 2 months ago
