HomeGuidesAPI Reference
GuidesAPI ReferenceGitHubAirheads Developer CommunityLog In
Data Push Destination Overview
Data Push Destination feature allows you to offload the three types of data: Test results, issues and incidents from UXI dashboard into storage systems like AWS S3, Google BigQuery, Elasticsearch, Generic HTTP Endpoint like ServiceNow, Splunk or BigPanda.
Below is the Test Result Schema:
Data Push Destinations - Test Result Schema
Below is the Issue Schema:
Data Push Destinations - Issue Schema
Below is the Incident Schema:
Data Push Destinations - Incident Schema
What’s Next
To get started, you can refer to this help article
