Export Inventory to CSV
An example of how to export your UXI resources to CSV files using the onboarding API.
The User Experience Insight (UXI) Onboarding API allows you to simplify most of the tasks associated with assigning your sensors and agents to the proper groups and configuring them to test your networks and services. To use the API, your dashboard must be on the Greenlake Cloud Platform. Additionally, you must be using the group-based assignment feature.
You can find documentation for the Onboarding API here: UXI API Reference Guide
Prerequisites
You will need to create a personal API client for the User Experience Insight service manager on the Greenlake Cloud Platform. See the detailed instructions on creating your personal API client in the Greenlake developer guide.
Example Scenario
In this example, suppose we want to get a complete inventory of all our resources and write the data to a collection of CSV files. This can be useful for inventory management, reporting and obtaining resource ID's for when we need to make additional calls to the onboarding API.
Endpoints
Here are the Endpoints you will need:
- networking-uxi/v1alpha1/groups
- networking-uxi/v1alpha1/sensors
- networking-uxi/v1alpha1/agents
- networking-uxi/v1alpha1/wireless-networks
- networking-uxi/v1alpha1/wired-networks
- networking-uxi/v1alpha1/service-tests
Note: The API uses cursor-based pagination.
Putting it together
Here is a Python 3 example of this in action. This example uses Python requests to fetch the data and write it to a CSV file.
This example does the following:
- Generates a temporary access token using the credentials of the personal API client.
- Retrieves a list of all groups, sensors, agents, wired and wireless networks as well as service-tests.
- Writes the details of each resource to a CSV file specific to that resource type.
WARNING
This example is for demonstration purposes only. This example lacks robust error handling and optimizations necessary for a production environment. Do not use the example code in a production environment.
import csv
from typing import Any
import requests
from oauthlib.oauth2 import BackendApplicationClient
from requests.auth import HTTPBasicAuth
from requests_oauthlib import OAuth2Session
# Global constants
AUTH_TOKEN_URL = "https://sso.common.cloud.hpe.com/as/token.oauth2"
UXI_API_BASE_URL = "https://api.capenetworks.com/networking-uxi/v1alpha1"
# Customer specific constants
CLIENT_ID = "<CLIENT_ID>"
CLIENT_SECRET = "<CLIENT_SECRET>"
def main() -> None:
api_token = get_api_token()
groups = get_groups(api_token=api_token)
sensors = get_sensors(api_token=api_token)
agents = get_agents(api_token=api_token)
wireless_networks = get_wireless_networks(api_token=api_token)
wired_networks = get_wired_networks(api_token=api_token)
service_tests = get_service_tests(api_token=api_token)
write_group_inventory_to_csv(groups)
write_sensor_inventory_to_csv(sensors)
write_agent_inventory_to_csv(agents)
write_wireless_network_inventory_to_csv(wireless_networks)
write_wired_network_inventory_to_csv(wired_networks)
write_service_test_inventory_to_csv(service_tests)
def get_api_token() -> str:
client = BackendApplicationClient(CLIENT_ID)
oauth = OAuth2Session(client=client)
auth = HTTPBasicAuth(CLIENT_ID, CLIENT_SECRET)
token = oauth.fetch_token(token_url=AUTH_TOKEN_URL, auth=auth)
return token["access_token"]
def get_groups(api_token: str) -> list[dict[str, Any]]:
return _get_items(path="groups", api_token=api_token)
def get_sensors(api_token: str) -> list[dict[str, Any]]:
return _get_items(path="sensors", api_token=api_token)
def get_agents(api_token: str) -> list[dict[str, Any]]:
return _get_items(path="agents", api_token=api_token)
def get_wireless_networks(api_token: str) -> list[dict[str, Any]]:
return _get_items(path="wireless-networks", api_token=api_token)
def get_wired_networks(api_token: str) -> list[dict[str, Any]]:
return _get_items(path="wired-networks", api_token=api_token)
def get_service_tests(api_token: str) -> list[dict[str, Any]]:
return _get_items(path="service-tests", api_token=api_token)
def _get_items(path: str, api_token: str) -> list[dict[str, Any]]:
HEADERS = {
"Authorization": f"Bearer {api_token}",
items: list[dict[str, Any]] = []
next_cursor = None
# This while loop exists to keep making requests until all data for the specified resource is fetched.
while True:
try:
params = {"next": next_cursor} if next_cursor else {}
response = requests.get(
f"{UXI_API_BASE_URL}/{path}", headers=HEADERS, params=params
response.raise_for_status()
response_body: dict[str, Any] = response.json()
response_items: list[dict[str, Any]] = response_body.get("items", [])
next_cursor = response_body.get("next")
items.extend(response_items)
if not next_cursor or not response_items:
break
except requests.exceptions.HTTPError as e:
print(f"Error fetching items ({path}): {e}")
break
return items
def write_group_inventory_to_csv(groups: list[dict[str, Any]]) -> None:
if not groups:
return
for group in groups:
del group["type"]
headers = list(groups[0].keys())
with open("group_inventory.csv", "w", newline="") as file:
writer = csv.writer(file)
writer.writerow(headers)
if group["parent"]:
group["parent"] = group["parent"]["id"]
writer.writerow(list(group.values()))
def write_sensor_inventory_to_csv(sensors: list[dict[str, Any]]) -> None:
if not sensors:
return
for sensor in sensors:
del sensor["type"]
headers = list(sensors[0].keys())
with open("sensor_inventory.csv", "w", newline="") as file:
writer.writerow(list(sensor.values()))
def write_agent_inventory_to_csv(agents: list[dict[str, Any]]) -> None:
if not agents:
return
for agent in agents:
del agent["type"]
headers = list(agents[0].keys())
with open("agent_inventory.csv", "w", newline="") as file:
writer.writerow(list(agent.values()))
def write_wireless_network_inventory_to_csv(wireless_networks: list[dict[str, Any]]) -> None:
if not wireless_networks:
return
for wireless_network in wireless_networks:
del wireless_network["type"]
headers = list(wireless_networks[0].keys())
with open("wireless_network_inventory.csv", "w", newline="") as file:
writer.writerow(list(wireless_network.values()))
def write_wired_network_inventory_to_csv(wired_networks: list[dict[str, Any]]) -> None:
if not wired_networks:
return
for wired_network in wired_networks:
del wired_network["type"]
headers = list(wired_networks[0].keys())
with open("wired_network_inventory.csv", "w", newline="") as file:
writer.writerow(list(wired_network.values()))
def write_service_test_inventory_to_csv(service_tests: list[dict[str, Any]]) -> None:
if not service_tests:
return
for service_test in service_tests:
del service_test["type"]
headers = list(service_tests[0].keys())
with open("service_test_inventory.csv", "w", newline="") as file:
writer.writerow(list(service_test.values()))
if __name__ == "__main__":
main()
Updated 21 days ago
