Elasticsearch
Selecting the Elasticsearch destination will send your test result data or issue data to your Elasticsearch database. Each test result will be an elastic search document. The data will be sent from the UXI VPC located in AWS US-WEST-2. It is recommended to use either the Elasticsearch cloud database or use the Elasticsearch on AWS or some other cloud provider. If your Elasticsearch is on-prem, it would require you to route the traffic accordingly. Elasticsearch 7.x is required.
This destination requires you to create a Kabana user to access to read and write to the specified index. The kabana user should only use basic auth.
Note that we have only tested the amazon elasticsearch service and the elasticsearch cloud.
Example Output:
CodeFree Graphs in Elasticsearch Cloud
Updated almost 3 years ago
For configuration you can refer to our help article here:
