Example Workflows
Ansible is a versatile technology that supports a wide range of applications. To begin automating your network, first, define the scope of your project including your desired automation objectives. Then come up with the process that will produce that outcome. Finally, you can get into the details, looking at modules, plugins, etc.
Simple ready-to-use workflows are available on the aoscx-ansible-workflows Github repository.
The subpages nested in this section go over workflow examples to showcase the synergy between the powerful and versatile AOS-CX and Ansible software!
Day 0 Provisioning
Day 0 provisioning is often the first goal in a network automation project. Automating the initial dynamic bring-up of a device drastically decreases the risk of human error and can prevent hours of network downtime. Approaches for this include:
- Generating a device configuration based on a "golden config" template, and pushing the config to the device
- Discovering a new device and configuring the desired features individually
See Day 0 Provisioning Workflows for details.
Network Maintenance
Once Day 0 automation is attained, meaning that devices can be provisioned and brought up on the network automatically, the next step is to automate regular maintenance and update tasks. Such tasks might include:
- Regularly-scheduled configuration backups, audits, or validations
- Incremental config changes like adding a VLAN or route across multiple switches
- Turning off PoE ports
- Upgrading firmware and rebooting devices
See Network Maintenance Workflows for details.
Updated about 2 years ago
