StackStorm with AOS-CX Actions and Websocket Sensor
In the AOS-CX pack we have actions that allow us to retrieve information from an AOS-CX device. We can use those actions in combination with our PortSensor to retrieve real-time device statistics in the event that an interface goes down on our AOS-CX device.
PortSensor Configuration
The AOS-CX PortSensor uses a websocket connection to subscribe to a list of interfaces and retrieve their admin status upon a change. To specify which interfaces we want to monitor and on which device, we have to define our aoscx configuration file in StackStorm. StackStorm configuration files are located in /opt/stackstorm/configs/
and typically have the format of packName.yaml
. Here's an example configuration file in which we've defined the device's IP, REST-API login information, and the interfaces we want to monitor:
credentials:
admin:
username: admin
password: admin
device:
ip_address: 10.100.206.188
hostname: 8320-CX-188
credentials: admin
interface:
- 1/1/1
- 1/1/23
- 1/1/14
proxy:
http: None
https: None
Once the configuration file contains the necessary information, run this StackStorm commands to reload configuration files in that path to ensure StackStorm has the contents:
st2ctl reload --register-configs
Define Rule, Trigger, and Action
Now that the PortSensor is monitoring the switch, we need to define the criteria for our trigger and the action to retrieve all interfaces' statuses. In the rule below, we're specifying the trigger to be our aoscx.port_status
and the criteria is when that value contains 'down'
meaning the interface is shutdown. Then we're using the aoscx.get_link_status
action to retrieve the interfaces of the device specified:
pack: "aoscx"
description: Using the AOS-CX Websocket PortSensor, retrieves the admin status of all interfaces on an AOS-CX switch when an interface goes down.
enabled: true
trigger:
type: aoscx.port_status
criteria:
trigger.admin:
pattern: "down"
type: "icontains"
action:
ref: "aoscx.get_link_status"
parameters:
ip: "10.100.206.188"
username: "admin" # REST-API Login username
password: "admin" # REST-API Login password
Once the rule is defined, we can add it into StackStorm with the following st2
command:
st2 rule create port_sensor_rule.yaml
You should see the following output if the rule was created successfully:
administrator@StackStorm-Ubuntu:~/stackstorm-aoscx/rules$ st2 rule create port_sensor_rule.yaml
| Property | Value |
| id | 5f6c9e3d99f71335767c235a |
| name | port_sensor_rule |
| pack | aoscx |
| description | Using the AOS-CX Websocket PortSensor, retrieves the admin |
| | status of all interfaces on an AOS-CX switch when an |
| | interface goes down. |
| action | { |
| | "ref": "aoscx.get_link_status", |
| | "parameters": { |
| | "ip": "10.100.206.188", |
| | "username": "admin", |
| | "password": "admin" |
| context | { |
| | "user": "st2admin" |
| criteria | { |
| | "trigger.admin": { |
| | "pattern": "down", |
| | "type": "icontains" |
| enabled | True |
| metadata_file | |
| ref | aoscx.port_sensor_rule |
| tags | |
| trigger | { |
| | "type": "aoscx.port_status", |
| | "parameters": {}, |
| | "ref": "aoscx.port_status" |
| type | { |
| | "ref": "standard", |
| | "parameters": {} |
| uid | rule:aoscx:port_sensor_rule |
Updated about 2 years ago
