NAPALM with StackStorm
With StackStorm's event-driven automation, users can make calls NAPALM calls based off of conditions from events detected on the network. NAPALM is usable in StackStorm using the NAPALM Integration Pack.
This allows for StackStorm uses to leverate NAPALM within StackStorm in the form of sensors, actions, and more.
Installation and configuration for StackStorm for AOS-CX can be found here.
Installation and configuration of the NAPALM Integration Pack can be found in their GitHub repo here.
Supported Actions with AOS-CX NAPALM Drivers
The actions that the StackStorm Integration Pack is a subset of the NAPALM AOS-CX Driver methods. Note that some have different function call names.
- get_arp_table
- get_bgp_neighbors
- get_bgp_neighbors_detail
- get_config
- get_facts
- get_interfaces
- get_lldp_neighbors
- get_mac_address_table
- get_ntp
- get_route_to
- get_snmp_information
Supported Sensors with AOS-CX NAPALM Drivers
The pack currently implements one sensor, largely for illustrative purposes.
- napalm.NapalmLLDPSensor: This detects any changes in the number of active LLDP neighbors
Example Workflow
This example workflow uses a webhook trigger to run an action chain when an interface goes down, posting to a Slack channel through a webhook. For more information about using StackStorm with a Slack Webhook, check out the StackStorm workflow with Ansible here.
version: '1.1'
napalm.interface_down_workflow:
input:
- hostname
- message
- interface
- slackwebhook
type: direct
task-defaults:
on-error:
- notify_on_error
tasks:
show_interface:
action: "napalm.get_interfaces"
input:
hostname: <% $.hostname %>
interface: <% $.interface %>
htmlout: true
on-success: "show_interface_counters"
show_interface_counters:
input:
htmlout: true
counters: true
on-success: "send_slack_notif_task"
send_slack_notif_task:
action: core.local cmd='curl -X POST "Content-type:application/json" --data "{\"text\":\"<% ctx().message %>\"}" <% $.slackwebhook %>'
Updated over 1 year ago
