Loopback Orchestration
Best Practice: Loopback Orchestration
- Multiple loopbacks supported
- Required for some features
- Setup under Loopback Orchestration
- Set up below, many options here Label and Zone are important, Region only matters if you are using regions.
- If management loopback, check the box.
- Orchestration loopbacks are in the 20,000 range
- Example lo20000
- Do not overwrite manually added loopbacks
Once you see the line click the “loopback pool” to assign an address pool
Usage tracked and decommissioned devices go into “reclaim” to reuse the IP click reclaim.
Updated 8 months ago
