HomeGuidesAPI Reference
Adding templates to groups
Open Templates
Open Template Groups from search menu
Click "show all"
Where to find template with show all
Where to find additional templates with show all
  1. Find the template you want
    1. Click-hold-drag to the right
    2. Demo to Click hold and drag needed template to the group.
      Configure the template as required.
  2. (1)Click Save
    1. Note the popup - telling you how many devices you are about to push configs too!
  3. Shortcut to Apply Template Groups
    (2)"Save as" can be used to clone an entire template group
    1. Uses:
      1. to apply the exact setting to a LAB environment to test changes without pushing to any Production appliances
  4. 📘
    Click the Circled "I" to understand when and why templates push.
  5. "Apply Template Groups" = shortcut to the apply template groups page.
    1. ❗️
      Templates will not change any configuration until applied to appliances
What’s Next
