HomeGuidesAPI Reference
VRRP General
Do not use VRRP and BGP together on the same VLAN/VIP
  1. Make a VLAN for VRRP to use if you only have one link for routing on the EC, this allows VRRP to monitor the health of LAN (cables/hardware/etc.) and EC for failover.
    1. /29 on a sub interface required
9.6 adds a Site/cluster tracking feature
Please review the "with" and "without" sections
This is a per Site/Cluster feature, depending on the VRRP config
Best Practice: Choose the method for the EC site/cluster
  1. Without Site/Cluster Tracking
  2. With Site/Cluster Tracking
Edge Connect route selection
Pre-9.6 (9.5,9.4 etc.)
  1. Longest Prefix
  2. AD (Lowest)
  3. Metric (Lowest)
  4. Peer Priority (Lowest, default 1024)
  5. Random - ECMP
9.6.2.x and later
  1. Longest Prefix
  2. AD (Lowest)
  3. Metric (Lowest)
  4. VRRP State Tracking (P) <<<<<NEW
  5. Peer Priority (Lowest, default 1024)
  6. BGP AS-Path Length (Shortest) <<<<<NEW
  7. Random - ECMP
NOTE: Route priority last updated/verified 15JUL2026
Enabling 9.6+ VRRP failover feature (Site/Cluster tracking).
You must enable the feature in the VRRP configs
VRRP WITH TRACKING
