HomeGuidesAPI Reference
Orch Tips and Tricks
What are the common tabs for troubleshooting?
  • Flows "Active and recent flows"
  • Tunnels
  • Routes
  • IP SLA Summary
  • Monitoring trends (loss, latency, etc.)
  • Audit Logs
  • DHCP Leases
  • Dashboard
  • Interfaces
  • Broadcast CLI (ARP table commands: “show arp” or “show neighbor”)
  • Deployment
  1. Pin your favorite tabs! (note: Orchy upgrade will reset the pins)
    Right Click and select “pin tab.”
Pin Tab option
Pin Tab option
  1. Click hold and drag tabs to a convenient order!
Colums
Many Display tables can display more columns.
You may drag and drop the columns in any order.
  1. Example: Flows tab Right click on header
    1. Select Data fields you want from this list.
    2. Recommend starting fields checked here.
    3. Sort table on most headers – Example: recommend “start time” for flows table.
  • Depending on your setup others will be useful.
    • “to zone” & “from zone”
    • “segment” & “roles”
    • “DSCP” for verifying QOS
