HomeGuidesAPI Reference
Regional Routing (RR)
Best Practice: ON (default)
Considerations:
  • Environment size and organizational requirements
  • 9.3.x.x and older
    30,000 route table limit
    9.4.x.x newer
    60,000 route table limit
RR affect routing advertisements from hub devices.
RR - OFF
  • Hub does not send other Spoke routes to spokes via SDWAN
  • Without a default route from the Hub, spokes cannot Hairpin through the HUB, need a route to attract the traffic to the hub, the hub routing table routes to the spoke.
    • Default route can be learned VIA BGP/OSFP or advertise only route.
      • RFC-1918 is also an option if default route is not an option
      • supnets/subnets of branches
      • Routes learned belong to the Zone they are learned in. More information in (Future link)
  • Example: RR off Spoke only see HUB routes
RR Off route table example
RR- ON
  • Hub sends all learned Spoke routes to all Spokes
    Metric of 50 added per hop, Maximum 2 hops
RR On route table example
Regional Routing (RR) affects the way routes are advertised in hub-and-spoke setups. In a mesh network, each appliance has routes to the appliances to which it has tunnels.
What’s Next
Configure ASN pool for RR to prevent routing loops.
