Orchestration Settings
• Idle Time (reduced Orchestration time)
• 30 is best for environments less than 100 appliances
• 60 is best for environments over 100 appliances
Auto flow reclassify - 60 (default) Can be reduced for faster HA appliance failover time, consult with SE before changing this.
A Burst of Flows can cause a crash if this is set too low - a internal security scan for example.
A future enhancement will negate this setting affecting failover times.
Firewall rules needed if EC is behind organization Firewall
- UDP IN/OUT for tunnel traffic ports used above
- Must bypass all inspection/scanning blades or performance will suffer, tunnel traffic is encrypted
- TCP 443 OUT to internet
- Can restrict to cloud portal and Orchestrator URL
- MUST bypass SSL inspection
- See Firewall Rules for more details
IPSec UDP Settings - Increment Port by 10 (default) Applies to appliances with same site name.
Updated 4 months ago
What’s Next
