HomeGuidesAPI Reference
Management Services
Best Practice: Management services applied as template
Defines the interface self-generated traffic will Source traffic, “makes it sticky.”
o The best practice setup is below
o NOT RECOMMENDED: changing DHCP, SSH, and HTTP(s) – Leave ANY and Default Segment
Setting HTTP(S), Cloud Portal, Orchestrator: away from "any" can result in appliance isolation, physical access will be required to recover.
SSH: any option other than "any" can break Orchestrator "CLI session" feature
Setting DHCP away from any: changes source address of DHCP relay traffic, can result in no IP or improper IP addresses to Hosts. DHCP server configs required to handle this.
Note: to change interface you must click “any” and delete “any” – interface options will then show.
